SNMP Monitoring of TFO Sessions
4gshute
I am interested in monitoring the performance of our WAEs using SNMP. I have had some success using the CISCO-WAN-OPTIMIZATION-MIB.
I have has some success in monitoring the sessions for each AO (but it is difficult to determine which AO is which)
.iso.org.dod.internet.private.enterprises.cisco.ciscoMgmt.ciscoWanOptimizationMIB.ciscoWanOptimizationMIBObjects.cwoAo.cwoAoStatsTable.cwoAoStatsEntry.cwoAoStatsActiveOptConns
A walk through the tree returns 7 stats (one for each AO I think).
However I am more interested in the TFO sessions, but the MIB appears not to return any values from the TFO objects:
.iso.org.dod.internet.private.enterprises.cisco.ciscoMgmt.ciscoWanOptimizationMIB.ciscoWanOptimizationMIBObjects.cwoTfo.cwoTfoStats.cwoTfoStatsActiveOptConn
Has anybody had any success with these variables in the MIB? Reporting session statistics to an SNMP management application would be very useful for trending and sizing WAAS deployments.
I am using WAAS version 4.4.5c and am not ready to upgrade to the latest release just yet.
Thanks in advance.
Graham
5 Replies 5
Nicolas Fournier
Hi Graham,
Could you try to poll the following OID:
.1.3.6.1.4.1.9.9.762.1.2.1.2
This should give you cwoTfoStatsActiveOptConn which is I believe what you are looking for.
Nicolas
Hi Nicolas,
Yes that is the OID that should report the number of sessions, but I am not getting a value returned.
However I do get a value from .1.3.6.1.4.1.9.9.762.1.3.1.1.11.4.99.105.102.115 which I believe is the CIFS AO current sessions. Could this me a MIB issue, or am I removing any dependencies on the MIB by using the OID directly?
Thanks for your help
Graham
Hi Graham,
Can you check the output of the following command on your device as it should give you the same value as the MIB:
show statistics connection optimized tfo
If you get values reported there and not on the MIB, it might be a bug which has been introduced in the latest software. Could you check if you have the same issue on WAAS devices running older code if you have any?
Nicolas
Definately sessions to report on:
AZ18NDL002#show statistics connection optimized tfo
Current Active Optimized Flows:                      6
   Current Active Optimized TCP Plus Flows:          3
   Current Active Optimized TCP Only Flows:          3
   Current Active Optimized TCP Preposition Flows:   0
Current Active Auto-Discovery Flows:                 0
Current Reserved Flows:                              10
Current Active Pass-Through Flows:                   6
Historical Flows:                                    367
D:DRE,L:LZ,T:TCP Optimization RR:Total Reduction Ratio
A:AOIM,C:CIFS,E:EPM,G:GENERIC,H:HTTP,M:MAPI,N:NFS,S:SSL,V:VIDEO
ConnID        Source IP:Port          Dest IP:Port            PeerID Accel RR
10274   10.208.176.243:7113     10.255.192.155:80 00:26:55:ae:43:58 THDL  97.5%
10406    10.255.170.73:3960     10.208.176.52:445 00:26:55:ae:43:58 TCDL  87.6%
11217    10.255.170.73:3145    10.208.176.51:3389 00:26:55:ae:43:58 T     00.0%
11523    10.255.170.73:2726    10.208.176.96:3389 00:26:55:ae:43:58 T     00.0%
11524    10.255.170.73:2759   10.208.176.127:3389 00:26:55:ae:43:58 T     00.0%
11862   10.208.171.11:65509     10.208.176.51:445 44:2b:03:7d:e6:00 TDL   00.0%
AZ18NDL002#
I could try some downgrading of code.
Have you used this before successfully?
Thank you for your help
Best regards
Graham
Hi Graham,
This should work so I would definitively give it a try.
Maybe you could install the latest 4.1 on a box and see if you get proper values with that one or if you already get zero for this OID.
Nicolas
