SorryServer with 443 - How to implement ?
cjrchoi11
Level 7
Level 7
Please clarify and correct my SorryServer with 443 scenario. normally, clients will be connected to S1 or S2 with the server's certification.
1. If S1 and S2 both down, clients will be redirecting to SorryServer and SorryServer will be issued the certification.
2. Client have a certification from server. S1 and S2 down in the middle of communication, what happen the client ? Is the client will get a certification request from SorryServer ? I'm not clear for the certification which already got from the server.
3. Last question. Is this right way to implement SorryServer with 443 ?
service S1
ip address 1.1.1.1
port 443
service S2
ip address 1.1.1.2
port 443
service SorryServer
ip address 1.1.2.1
port 443
content SecureServer
vip address 2.2.2.2
add service S1
add service S2
advanced-balance sticky-srcip
primarySorry SorryServer
port 443
Thanks in advance.
stevehall
Level 4
Level 4
Well,
Assuming you activate the services with the "active" command.. 🙂
If something goes wrong in the middle of a flow (or conneciton) then there is not much we will do. The sorry server does not have a socket for that specific connection. If we did send it there, we would only get a TCP RST response. The sorry service will get all NEW connections if all the other services go down.
Other than not having "active" services, and I am not sure on the content rule (It needs to be active also!) the way you have configured it is fine.
-Steve
stevehall
Level 4
Level 4
Well,
-Steve
