source ip filtering with class map on cisco ace30
fd_case17
Hello ,
I would like to know if it is  possible to filter source ips connecting to a virtual ip  within a class map configuration ( or something else  ) ?
access-list S_IP_FILTERING line 8 extended permit ip host 1.1.1.1 any
class-map match-all S_IP_FILTERING_XVIP
2 match access-list S_IP_FILTERING
3 match virtual-address 2.2.2.2 any
Error: Only one match access-list is allowed in a match-all class-map and it cannot mix with any other match type
thanks for your support
Case,
Alex Rickard
Yes, it is possible to do this. Use the ACL filter for the source IP address under the policy-map type loadbalance. Then you would call that load balance policy in your multi-match policy under the appropriate class.
for example:
class-map type http loadbalance match-any LOADBALANCE-FILTER
  2 match source-address X.X.X.X 255.255.255.255
class-map match-any TEST-CLASSMAP
  2 match virtual-address Y.Y.Y.Y tcp eq www
policy-map type loadbalance first-match LOADBALANCE
  class LOADBALANCE-FILTER
    serverfarm TEST-SERVERFARM
policy-map multi-match UTC-PM
  class TEST-CLASSMAP
    loadbalance policy LOADBALANCE
    loadbalance vip inservice
-Alex
Alex Rickard
for example:
  class TEST-CLASSMAP
-Alex
Hi Alex,
Thanks, it works
FD.
