special cable for CSS
lyesinn.ang
I havce a new CSS 11000 but it seem that i have misplace all the cable. Is there anyway i can configure the the CSS. I had tried the consloe cable but with no avail. Is there a default IP with i can use via the management port.
Please Advise. Thanks
drussell
Level 3
Level 3
The console pinout is not a standard Cisco pinout.:
CSS (11000): RJ-45
1 DTR
2 TX -> *
3 RX <- *
4 RTS
5 CTS
6 DSR
7 GND *
8 DCD
*min required, -> means leaving the CSS, <- entering the CSS
David
drussell
Level 3
Level 3
CSS (11000): RJ-45
1 DTR
2 TX -> *
3 RX <- *
4 RTS
5 CTS
6 DSR
7 GND *
8 DCD
David
Hi David,
This is one end of the RJ-45, may I know what will be the pin out for the other end of the cable?
The following cable pinout can be used for connecting the CSS 11000 console to a PC with a standard Cisco DB-9 adapter. Please see the Related Informationsection for more information about cable pinouts for the CSS 11000 series.
Full Cable (includes rollover and it is reversible):
-----Comm-server-side -----------------------------------Arrowpoint-side------------
---Color----------Purpose --- PIN #--- PINOUT -----PIN #----Purpose----------Color--
white-orange-----CTS-----------1--      1-1        --1------------------white-orange
------orange-----DSR-----------2--      2-6        --2---------RxD-------------green
-white-green-----RxD-----------3--      3-3        --3---------TxD-------white-green
--------blue-----GND-----------4--      4-7        --4-------------------white-brown
--white-blue-----GND-----------5--      5-5        --5--------------------white-blue
-------green-----TxD-----------6--      6-2        --6------------------------orange
-white-brown-----DTR-----------7--      7-4        --7---------GND--------------blue
-------brown-----RTS-----------8--      8-8        --8-------------------------brown
This comes from the following url:
http://www.cisco.com/en/US/partner/products/hw/contnetw/ps789/products_tech_note09186a00800a3f28.shtml#cable
Gilles.
If you want to connect to a PC :
CSS (11000): RJ-45 Standard PC 9 pin Serial port
1 DTR
2 TX -> * 2
3 RX <- * 3
4 RTS
5 CTS
6 DSR
7 GND * 5
8 DCD
good luck, you are working with the most difficult protocol of all RS-232.
