SSL and WebCT application header
smorytko
We've traced a problem with our setup of a CSS11503 w/ 1 SSL card and WebCT/Vista to the following cause.
The WebCT/Vista app expects to see the header
WL-Proxy-SSL: true
with every HTTP request, so we added the following line to to the ssl-proxy-list section of our config:
ssl-server 20 http-header static "WL-Proxy-SSL: true"
but as we have since discovered in the following Cisco web documentation (look for the 'Note' on the linked page)
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_740/cmdrefgd/cmdsslc.htm#wp1172789
"HTTP header insertion only occurs on the first HTTP request for a persistent HTTP 1.1 connection. Subsequent requests within the same TCP connection are sent unmodified."
In other words, WebCT/Vista is not always getting this header (I've verified this via network traces), and this is what is causing the application to fail.
It there a way to get CSS11503 to include the header for *all* HTTP requests?
I've attached relevant parts of our config file.
Thanks in advance.
Steve
Gilles Dufour
there is no way to force the css to insert it for every request.
Only solution is to disable persistence on the server.
Force the server to work in HTTP/1.0 mode.
A feature request has already been intoduced to have the info inserted in every request.
Gilles.
