Showing results forĀ
Search instead forĀ
Did you mean:Ā
ssl connection through a ACE , with dual certificates
Jan Loop
hi
i have a new setup with some ipsec challenges
i have a public certificate pointing the outside, and a internal on the servers
i have a new exchange enviroment and need to run ipsec between a client to a TMG server  , where the trafic terminate andinitialte from the TMG further to a ACE cocntext, where it shall be load balanced and from the ace to the final serve(internal certificat) (offcourse with sticky sessions)
i have found this page http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/ssl/guide/endtoend.htmlhttp://http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/ssl/guide/endtoend.html
but seams to need a more visual example ,can anybody help
Jan
pablo.nxh
Level 3
Level 3
Hi Jan,
The config you need would depend on whether your TMG sends the traffic unencrypted to the ACE VIP or if it decrypts/encrypts the traffic prior sending it to the ACE.
If the traffic goes unencrypted you need a SSL initiation config where the traffic path is the following:
Client -->(Encrypted)---->
TMG -->(decrypted)---->ACE-->(Encrypted)----> Server
Here is the wiki info for SSL initiation config on the ACE, if you need a bigger picture you can look for SSL initiation on the CSS as it is the same concept
http://xrl.us/bh75ys
Now if your TMG server decrypts the client traffic but it encrypts it again before it goes to the ACE then you need End-2-End SSL to make this work.
Client -->(Encrypted)---------->
TMG------>(Encrypted)---->ACE-->(Encrypted)----> Server
                                    (decrypted|encrypted)
Here is a good paper about end to end SSLdetails and t-shooting
http://xrl.us/bh75y6
__ __
Pablo
