SSL Termination Issue on ACE
kalugotla1
I configured SSL on my ACE.Applied it to the loadbalancer my current vip.
When I hit the VIP IP as HTTPS.  .IT is displaying page cannot be displayed . But with out the SSL the loadbalancing works fine
This is the config I have on my ACE
crypto csr-params test123
  country US
  state CAlifornia
  locality Torrance
  organization-name USA
  organization-unit ITprobe tcp ftp_tcp
    common-name USA  serial-number 1
  email randy.alpha@gmail.com
access-list ALL line 8 extended permit ip any any
probe tcp ftp_tcp
  port 21
  interval 10
  passdetect interval 5
  passdetect count 1
  open 1
rserver host server1
  ip address 10.128.149.86
  inservice
rserver host server2
  ip address 10.128.149.171
  inservice
serverfarm host FTPFARM
  predictor leastconns
  probe ftp_tcp
  rserver server1
    inservice
  rserver server2
    inservice
ssl-proxy service proxy-1
  key rsa.pem
  cert trialcert.pem
sticky ip-netmask 255.255.255.255 address source sticky_FTPFARM
  timeout 20
  timeout activeconns
  replicate sticky
  serverfarm FTPFARM
class-map match-all L4-MAP-FTPFARM
  2 match virtual-address 10.128.149.173 any
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match L7-FTPFARM
  class class-default
    sticky-serverfarm sticky_FTPFARM
policy-map multi-match L4-PolicyMapMulti-FTP
  class L4-MAP-FTPFARM
    loadbalance vip inservice
    loadbalance policy L7-FTPFARM
    nat dynamic 2 vlan 817
interface vlan 817
  ip address 10.128.149.55 255.255.255.0
  peer ip address 10.128.149.56 255.255.255.0
  access-group input ALL
  nat-pool 2 10.128.149.173 10.128.149.173 netmask 255.255.255.255 pat
  service-policy input remote_mgmt_allow_policy
  service-policy input L4-PolicyMapMulti-FTP
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.128.149.1
did that command take? It should be:
ace1/Admin(config)# policy-map multi-match L4-PolicyMapMulti-FTP
ace1/Admin(config-pmap)# class L4-MAP-FTPFARM
ace1/Admin(config-pmap-c)# ssl-proxy server proxy-1
thompso7540
You have to apply your ssl proxy service to your l4 policy map
I applied the ssl proxy to the my policy multimatch
ace1/Admin(config-pmap-c)# ssl-proxy service proxy-1
ace1/Admin(config-ssl-proxy)# exit
ace1/Admin(config)# exit
But when I give a sh run all I see under the L4 policy map is
When I try to access the server with the VIP IP using HTTPS  still getting the message (Message Cannot Be Displayed).But works great with HTTP
Please advise.
