TCP Timeout on backend sessions
soumya.sarkar
We are using the CSS5-SSL-C-K9 module.
We use front-end and back-end ssl sessions for our https app.
i.e. :
browser -- ssl traffic -- sslrule -- K9cardfrontserver -- contentrule -- K9cardbackendserver -- realbackendserver.
We specify flow-timeout-multiplier 400 to avoid timing out the flows for the content rules.
But we still see the backend tcp session being closed after about 4-5 mins of idle i.e. server sleeps before response.
We do not want this to time out.
Any ideas what could be missing ??
Gilles Dufour
the flow timeout command is for the css not to delete the flow.
But the SSL module as also its own timeouts.
CSS11503-2(config-ssl-proxy-list[gdufour])# ssl-server 1 tcp ?
inactivity-timeout Specify the server-side SSL TCP inactivity timeout
The default is 240 sec.
You can increase it to 3600 sec max.
The same command exist for the front-end connection.
Gilles.
