Timeouts on non load balanced traffic thru ACE
k-bragg
I have a backend server creating a connection to a db server outside the ACE environment. This traffic is using the L3 function of the ACE and is not being load balanced. The connection is timing out after 1 hour. I have normalization disabled on the backend server VLAN but not on the front side VLAN of the ACE.
2 Questions:
- With normalization disabled do I still need to change the tcp inactivity timeout for this traffic? Or with normalization disabled shouldn't the non load balanced traffic be L3 routed and not effected by the tcp timeout value?
- Also do I need to disable normalization on the front side VLAN of the ACE?
thanks,
kurt
As per
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/security/guide/tcpipnrm.html#wp1075741
"Disabling TCP normalization affects only Layer 4 traffic. TCP normalization is always enabled for Layer 7 traffic."
By disabling TCP normalization the following Layer 4 connection parameters are ignored.
exceed-mss-----Configure behavior if a packet exceeds MSS
random-seq-num-disable----Disable TCP sequence number randomization
reserved-bits-----Configure Reserved bits in TCP header
syn-data-----Configure behavior for a SYN packet containing data
tcp-options-----Configure TCP header options
urgent-flag-----Allow/Clear Urgent flag
I think you will need "Set timeout inactivity xxxx" command even if "no normalization" command is defined.
Syed Iftekhar Ahmed
