Traffig shaping Nexus 7K
somouraeng
Good Morning!
You can perform traffic shaping configuration on the Nexus 7000 and set the IP source and destination? What would be the setup to do?
Philip D'Ath
I don't know the answer, but found this post.
https://supportforums.cisco.com/discussion/11008441/nexus-7k-egress-traffic-shaping
Jeey Ye says:
Looks like you want to configure some type of MQC shaping in the N7K. The only shaping that is supported in the N7K is Shaped Round Robin (SRR) on the egress port. The shaping is based on COS value where the COS are mapped to queues and each queue is given a specific rate. Here is an example on N7K shaping from NXOS 4.2
Philip, thanks for the answer.
If you think it was helpful it would be great if you could rate and mark it as an answer.  :-)
