Upgrade IOS for cisco ASR1001-X
loc.nguyen
I need help to confirm if my setting is correct before I reboot the router. This is a production router so I have to be careful.
I need to upgrade IOS for my ASR1001-X  from asr1001x-universalk9.17.03.03.SPA.bin to c1100-universalk9.17.03.06.SPA.bin
 I did copy the new OS to flash, and set up boot command as below:
rss1-rtr#show run | i boot
boot-start-marker
boot system flash bootflash:c1100-universalk9.17.03.06.SPA.bin
boot system flash bootflash:packages.conf
boot-end-marker
rss1-rtr#show boot
BOOT variable = bootflash:packages.conf,1;flash:/bootflash/c1100-universalk9.17.03.06.SPA.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
rss1-rtr#
Is it good enough for me to reboot or I need to be aware of something?
Please advise.
Loc
5 Replies 5
balaji.bandi
Can you post show version before you reboot :
Looks like the router in install mode, so you need to use install method to upgrade
i can see packages.conf file that means install mode (but we can only confirm based on show version and dir (full output here)
if you have logs  show install log
BB
rss1-rtr#show version
Cisco IOS XE Software, Version 17.03.03
Cisco IOS Software [Amsterdam], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.3, RELEASE SOFTWARE (fc7)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Thu 04-Mar-21 12:36 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 17.3(1r)
rss1-rtr uptime is 1 day, 8 hours, 39 minutes
Uptime for this control processor is 1 day, 8 hours, 42 minutes
System returned to ROM by Reload Command at 01:42:49 PST Thu Feb 9 2023
System restarted at 01:46:47 PST Thu Feb 9 2023
System image file is "bootflash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Smart License is permanent
License Level: advipservices
Next reload license Level: advipservices
The current throughput level is 2500000 kbps
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ASR1001-X (1NG) processor (revision 1NG) with 3756810K/6147K bytes of memory.
Processor board ID FXS2314xxx
Router operating mode: Autonomous
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6594559K bytes of eUSB flash at bootflash:.
rss1-rtr#
#dir (output please)
System image file is "bootflash:packages.conf"  - as per this you have install mode so you need to install using .bin file follow below guide
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/software/configuration/xe-17/asr1000-sw-config-xe-17/issu-asr.html
BB
rss1-rtr#show install log
[0|install_op_boot]: START Thu Feb 9 08:45:38 Universal 2023
[0|install_op_boot(INFO, )]: Mount IMG INI state base image
[0|install_op_boot]: END SUCCESS Thu Feb 9 08:45:39 Universal 2023
Leo Laohoo
WTF.
I can guarantee the router will not boot 17.3.6.
Reason?  Because the 17.3.6 firmware file is meant for an ISR 1100.
