Using source group criteria
y.lo
Level 3
Level 3
I got below configurations.
!************************** SERVICE **************************
service server1
  protocol udp
  port 22015
  ip address 172.20.117.71
  active
!*************************** OWNER ***************************
owner com
  content rule1
    add service server1
    vip address 192.168.1.10
    protocol udp
    port 464
    active
!*************************** GROUP ***************************
group NAT
  add service server1
  active
When the server1 initiates outgoing telnet traffic (port 23), the CSS translates the source IP to IP address 192.168.1.10. Is this behavior expected?
As port 22015 is configured under the service server1, so I expect the CSS only performs NAT if the port of the connection is 22015.
Does that mean the CSS does not care about the port of the connection when performing NAT, but only the IP address?
Daniel Arrondo Ostiz
Yes, this is the expected behavior. The port is not taken into account for outbound connections. The main reason for that is that, the port defined under the service or the content rule is the port on which the server is listening, but this port will never be used for outbound connections
Daniel
