Using WAVE-7371-K9 with inline and WCCP Interception together
lomonaco
Hi guys,
   I have an WAVE-7371-K9 with WAE-INLN-4CG.
   Is there any way to use both modes inline (in-path) and WCCPv2 Interception at the same time in this appliance ?
   I think you can use just one mode (in-path or off-path), but I wanna confirm that
   Thanks in Advanced
   My Best Regards,
   Andre Lomonaco
2 Accepted Solutions
ahskhan
Hi  Andre,
  You can only use one interception method, Either WCCP or INLINE on any WAAS device. Thank you.
Ahsan
hi lomonaco
yes ahsan, is Right, you can use only one interception method, Either WCCP or INLINE, But For INLINE Feature you need Inline Card which got Supported in Your Device.
Also There is NO Need To have Same Interception Method to be used if you are Using Waas Devices in Two or more Branches.
A.Dixit
ahskhan
Hi  Andre,
Ahsan
hi lomonaco
A.Dixit
