vip & interface redundancy for css11506
julxu
Level 7
Level 7
When I configure redundancy on my two css11506s, I find when I put acl on, I can not see the vip if not working fine.
and also, if remove redundancy it works fine.
my access list is only bypass ssh and permit VIPs. do I need add more for redundancy?
Any comments will be appreciated
Thanks in advance
Gilles Dufour
if you create acl, you need to permit the vrrp traffic [dst ip == 224.0.0.18].
Gilles.
Thanks for rating this answer.
Gilles Dufour
Gilles.
what is the source ip ? I did:
master:
circuit VLAN295
ip address 10.2.95.2 255.255.255.0
ip virtual-router 2 110 preempt
ip redundant-interface 2 10.2.95.1
ip critical-service 2 upstream-downstream
backup:
circuit VLAN295
ip address 10.2.95.3 255.255.255.0
ip virtual-router 2
so the acl should be:
clause 1 permit ip 10.2.95.2 destination 224.0.0.18?
Should I use bypass?
Should I use src ip as any?
Please advance.
I think I found the solution myself. the src should be the interfaces of vrrp.
I will try today and thanks for help.
the source is the ip address configured on the interface where you configured the virtual vip or virtual interface.
So in your example, your clause 1 is correct.
Gilles.
