VLANs to ACE module
danger_mousie
I have a mgt VLAN going between the Sup in 6500 and the ACE.
ON 6500:
vlan 16,500
svclc module 1 vlan-group 500
svclc vlan-group 500 500-550
interface Vlan500
description Mgt VLAN
ip address 1.1.1.3 255.255.255.240
ON ACE
class-map type management match-any Mgt_Class
! Management VLAN sources - VLAN 500
2 match protocol telnet source-address 2.2.2.0 255.255.255.240
3 match protocol icmp source-address 2.2.2.0 255.255.255.240
policy-map type management first-match Mgt_Policy
class Mgt_Class
permit
interface vlan 500
desc Mgt VLAN
ip address 1.1.1.5 255.255.255.240
service-policy input Mgt_Policy
no shutdown
I am trying to add my first vip to a context and am setting up the VLAN..
ON 6500
6509-1(config)#int vlan 511
6509-1(config-if)#ip address 3.3.3.1 255.255.255.252
6509-1(config-if)#desc VLAN for VIP-A
6509-1(config-if)#no shut
Forcing SVI 511 to stay shutdown (SVI 500 tied to line card in slot 1.)
I found this online:
Once the VLANs are assigned to the module, only one interface VLAN (Layer 3 interface) can be configured for one of the VLANs assigned to the module. When an attempt is made to assign a Layer 3 interface to more than one of the VLANs, the above error msg is given.
I want to create VLAN 511 and give it an IP address in the subnet that my VIP is in and then redistribute connected. How can this be done to get routing to the VIP network established.
diro
ON 6500:
vlan 16,500
svclc multiple-vlan-interfaces
To enable multiple switched virtual interfaces (SVIs) to be configured for a SAMI, use the svclc multiple-vlan-interfaces command in global configuration mode. To remove this configuration, use the no form of the command.
Thanks, is this method best practice? Or should I route everything through the one VLAN. It gave a warning about traffic bypassing the ACE. How can I make sure this doesn't happen? In what scenario does this occur?
