VMs change OID and fails SNMP probe on ACE module
mfreivald
I am setting up least loaded load-balancing on a serverfarm. It seems to work fine when all servers have the same OIDs, but the VMs change OIDs for the CPU utilization every time they vMotion or reboot, and that causes the SNMP probe to fail.
Is there any known solution to fix that problem?
Thank you,
Mark
Kanwaljeet Singh
Hi Mark,
If the OID's change itself on servers then this is expected. I am aware of anything that we can do on ACE to update the OID's automatically.
Kanwal
