vWAAS not starting after deploy from OVA.
Bruno Rangel
Hi All
We are trying install vWAAS-1300 under ISR 2911 (UCS-E120) and ESXi 5.5, using the OVA Cisco-vWAAS-1300-5.3.5b and Cisco-vWAAS-1300-6.2.3a-b-39.
When I´m going to start the Guest Virtual Machine, the VM is not able to start, received the error:
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
finn.poulsen
Level 3
Level 3
Hi Bruno,
Assume that is it the EN120S and not the EN120E (EHWIC) module you're using ?
Have you enough DRAM on the EN120S ?
Default when purchased is 4 GB, but vWAAS-1300 requires 6GB, as stated in your screen dump.
Best regards
Finn
finn.poulsen
Level 3
Level 3
Hi Bruno,
Best regards
Finn
Just found the solution... In the VM resources, it was allocating some memory resources.
Anyway, thanks Finn for your time (5stars), fyi my system have 8G RAM.
T
Cheers
Bruno Rangel
