WAAS 4.1.3 prepositioning problem
jeffrey_ala
I'm trying to setup prepositioning and am unable to browse the root share and directories when setting up the preposition. I am using an AD account with the proper access and can map drives and access files using this account from my workstation. The error I receive is
"Could not access cifs://xxxserver.au.net/"
Any idea where to start? I've tried to specify by ip as well with no luck.
jeffrey_ala
If I leave the "location" field under preposition settingn set at "please make a choice" I am able to browse the directories on the on the server? As soon as I choose the location closest to the server it fails.
Please verify DNS server settings on all WAE appliances.
