WAAS and cache capacity
pthaynes
I am having trouble locating a document that outlines the amount of disk space available for file cache for each of the WAE models. The models I am considering are the NME-WAE-502 (we use 2800 series routers so this is the biggest NM we can support), the WAE-512 and WAE-612.
I was also wondering if this changes depending upon the software version used. For the NME-WAE-502 it seems to have a file cache of about 40GB (from looking at the graphs on our pilot WAAS).
Thanks in advance for any help,
Peter
Zach Seils
Level 7
Level 7
Peter,
The disk space allocation depends on the amount of memory in the WAE. The current allocation per model is:
NME-WAE-302 - 80GB disk, DRE 55GB
NME-WAE-502 - 120GB disk, DRE 47GB, WAFS 47GB
NME-WAE-522 - 160GB disk, DRE 67GB, WAFS 67GB
WAE-512 w/ 1GB of memory, 250GB disks (RAID-1) - DRE 75GB, WAFS 110GB
WAE-512 w/ 2GB of memory, 250GB disks (RAID-1) - DRE 110GB, WAFS 110GB
WAE-612 w/ 2GB of memory, 300GB disks (RAID-1) - DRE 130GB, WAFS 130GB
WAE-612 w/ 4GB of memory, 300GB disks (RAID-1) - DRE 130GB, WAFS 130GB
WAE-674 w/ 4GB of memory, 300GB disks (RAID-5) - DRE 120GB, WAFS 120GB
WAE-674 w/ 8GB of memory, 300GB disks (RAID-5) - DRE 120GB, WAFS 120GB
WAE-7326 w/ 4GB of memory, 6x300GB disks (RAID-1) - DRE 300GB, WAFS 300GB
WAE-7341, 4x300GB disks (RAID-5) - DRE 500GB, WAFS 220GB
WAE-7371, 6x300GB disks (RAID-5) - DRE 1TB, WAFS 200GB
Zach
Zach Seils
Level 7
Level 7
Peter,
Zach
Zach,
Thanks - that is exactly what I was looking for.
Peter
