WAAS - Changing hostname
tverhoeven
We were recently rushed into putting out test WAAS units into production and now we want to go back and change the hostnames as well as add SNMP, syslog, motd and tacacs.
Is there any problems with changing the hostnames on these things?
Anything I should be watching out for with the other changes I want to make??
thanks
tony
dstolt
Tony,
You can change the hostnames via CLI or CM GUI without issue. They are kept in an internal database so changing them doesn't effect any configs. Adding configs via the CM after they are deployed shouldn't be an issue either.
Dan
