WAAS connection to router.
dan.levin
When connecting WAAS directly to router interface, is a straight through cable used?
dstolt
Dan,
If you are using 100 mb, then you should use a crossover. if you are using 1000 mb (gig), then it shouldn't matter.
Hope that helps,
Dan
