WAAS disabling virtual Blade feature
y_ananthan
Dear Expert,
I was ask to disable the virtual blade features in our WAVE-694-K9 (running universal-k9 Software Release 4.4.5d). I try  issue the command
          1. virtual-blade 1 stop  in exec mode ( I did for all 1-6)
          2. no virtual-blade 1 in global config mode ( I did for all 1-6)
Commands are taken by device. After i did the restart  the devcie when i check the config ,the command  "virtual-blade enable" still appeared in show run output. Could you please advise me how we can disable this feature from the box ?
Thank you.
-Ananthan
Kanwaljeet Singh
Hi Ananthan,
Please go to the below link for details:
http://www.cisco.com/c/en/us/products/collateral/routers/wide-area-application-services-waas-software/white_paper_c11-609580.html#wp9000018
It seems you cannot undo(disable VB once you enable it) unless you reinstall the WAAS software using recovery CD. Once virtualization is enabled, system resources are reserved and are not available for your WAAS system even if VB is not active.
Please visit section: "Preparing to use Virtual Blades".
Kanwal
