% waas enable failed: WAAS memory requirements not met
ranjith.kanisan
Dear Team,
We have upgraded our WAAS devices to 5.0.1 and upgraded the brach router that having waas express license to 15.2 3 T. Now we are getting following error while we are enabling the waas from WAN interface.
% waas enable failed: WAAS memory requirements not met.
before upgrading the branch router itsWAAS  working fine and we are facing this issue after upgrading the router from 15.1 to 15.2.
Branch router Model: 1941.
Kindly suggest why we are getting these error while we are enabling the WAAS in Wan interface.
Please find the below mentioned show version output from branch router.
BRouter#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 23-Mar-12 15:35 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
HB2503R0 uptime is 4 hours, 50 minutes
System returned to ROM by reload at 17:25:07 IST Sat Sep 22 2012
System restarted at 17:26:42 IST Sat Sep 22 2012
System image file is "flash:c1900-universalk9-mz.SPA.152-3.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco CISCO1941/K9 (revision 1.0) with 2269152K/90112K bytes of memory.
Processor board ID FGL1549221B
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded service engine(s)
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1941/K9          FGL1549221B
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
               Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
data          None          None           None
Brouter#
Brouter#sh flash
-#- --length-- -----date/time------ path
1     55398712 Nov 29 2011 20:37:04 +05:30 c1900-universalk9-mz.SPA.151-4.M2.bin
2         2903 Nov 29 2011 20:58:52 +05:30 cpconfig-19xx.cfg
3      3000320 Nov 29 2011 20:59:06 +05:30 cpexpress.tar
4         1038 Nov 29 2011 20:59:16 +05:30 home.shtml
5       122880 Nov 29 2011 20:59:24 +05:30 home.tar
6      1697952 Nov 29 2011 20:59:38 +05:30 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Nov 29 2011 20:59:52 +05:30 sslclient-win-1.1.4.176.pkg
8     66415436 Sep 22 2012 17:24:06 +05:30 c1900-universalk9-mz.SPA.152-3.T.bin
129417216 bytes available (127070208 bytes used)
Brouter#sh hardware
Brouter uptime is 4 hours, 51 minutes
1 terminal line
We are geeting the "SSL hand shake failed while communicating with WAAS express device " critical warning from Central manger GUI for the same branch express. Kindly suggest how we can resplve this issue.
Thamks in Advance.
Regards.
Ranjith
Nicolas Fournier
Hi Ranjith,
Can you try the following commands on your router and see if it helps:
configmemory-size iomem 5
If it doesn't and that you are sure you have enough memory on your router to support WAAS Express, I would advise you to open a TAC case to have this investigated in depth.
Nicolas
