WAAS MAPI less no. of optimized connections
Kashish_Patel
Level 2
Level 2
We have deployed Cisco WAAS in our network. Most of the acceleration works great except one issue: MAPI accelerated sessions are quite less in number:
MAPI:
   Global Statistics
   Time Accelerator was started:                                      Thu Feb  7
06:08:56 2013
   Time Statistics were Last Reset/Cleared:                           Thu Feb  7
06:08:56 2013
   Total Handled Connections:                                         47
  Total Optimized Connections:                                       1
   Total Connections Handed-off with Compression Policies Unchanged:  46
   Total Dropped Connections:                                         0
   Current Active Connections:                                        0
   Current Pending Connections:                                       0
   Maximum Active Connections:                                        1
   Total Secured Connections:                                         47
Any clue on this?
waas#sh accelerator
Accelerator        Licensed           Config State       Operational State
cifs               Yes                Enabled            Running
epm                Yes                Enabled            Running
http               Yes                Enabled            Running
mapi               Yes                Enabled            Running
nfs                Yes                Enabled            Running
ssl                Yes                Enabled            Running
video              No                 Enabled            Shutdown
Felix Arrieta
Hello Kashish,
Did you follow the configuration guide and best practices ? if not, I suggest to look up for the configuration docs for whatever version you are running, you could be missing important notes like the one below.. which  could explain why the traffic is not being optimized.
Microsoft Outlook 2007 and 2010 have encryption enabled by default. You must disable encryption to
benefit from the MAPI application accelerator.
cheers,
Felix Arrieta
Hello Kashish,
cheers,
Thanks Felix. That was the reason!
