Waas mobile with Microsft UAG
ambi
Has anyone faced any problems deploying Waas mobile with Microsoft UAG ?
we seem to be running into a problem where the UAG is dropping packets and allowing the client to connect to the Waas server
Are there any specific guidelines available for deploying Waas when using UAG as the SSL gateway?
Ambi
We have not tested with this product, but usually SSL VPN issues are worked around via configuration settings on WAAS Mobile or the SSL VPN side.  Please open a TAC case that will allow us to gather the required information and assist you with the configuration.
base-it
hy ambi
did you collect some experience with uag and waas mobel client?
kind regards - michael
Unfortuantely no Michael
We went ahead with Riverbed
ambi
hy ambi
thank you for your feedbak.
you use riverbade and uag wirth direct access, is this correct?
greets - michael
