WAAS Module stops routing
romueller
HI,
I have a strange problem. We have 6 WAAS Modules installed in C3945 Routers with the Enterprise License. The CCM ganz reach the modules do what the should do but after about 4 hours 2 of the modules stops forwarding the traffic they are not able to ping the router where they are installed BUT i can login onto the modules from outside (with telnet on port 2067). After a reload of the module (service-module sm 1/0 reload) the devices work again.. there are no LOG entries or something else what can be a hint of the problem.. we have the firmware 4.4.3 installed..
Can someone explain me what happens and how to solve it?
Thx
Robert
Jorge Bejarano
Level 4
Level 4
Robert,
You may try to get a Sysreport and open a TAC case
Jorge
