WAAS on Nexus - ITD, PBR?
Aaron Harrison
We currently have a pair of WAVE694s with AppNav controllers, and a futher two 694s as WAAS engines all in a single AppNav cluster. These are connected to some 3750x switches which use WCCP to divert traffic.
I'm looking at a Nexus based design for a new DC, and wondering what the best practice is for integrating WAAS with these switches - Nexus 9504 core, with some Nexus 9372s.
I've seen reference to using ITD with WAAS, but no specific detail - like here: https://blogs.cisco.com/enterprise/itd-intelligent-traffic-director
- Has anyone deployed ITD for WAAS?
- Is it a 'TAC supported' solution?
- What are other options on Nexus 9k - presumably just PBR?
Thanks!
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
lauresfrank
Hello!
Yes, same question here. We have 2x N9K-C93180LC-EX as DC Core with 7.0(3)I7(7) and WAAS WAE-694 with 6.4.3d software.
As DC-Core does not support WCCP, it looks like we need to go with ITD.
Will it work according to the config guide example Configuration Example: ITD as WCCP Replacement (Web-Proxy Deployment Mode)? Or anyone has an example config?
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/itd/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Intelligent_Traffic_Director_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Intelligent_Traffic_Director_Config...
Thank you.
Should look something like this but I am not sure.
! Send through WAE to remote sites
ip access-list ITD-LAN-TO-WAN
 permit tcp any 10.100.16.0 0.0.0.255
! Dont send through WAE to remote sites ip access-list ITD-LAN-TO-WAN-EXCLUDE permit tcp 10.100.43.0 255.255.255.7 any
! Send through WAE from remote sites ip access-list ITD-WAN-TO-LAN permit tcp 10.100.16.0 0.0.0.255 any
! Dont Send through WAE from remote sites ip access-list ITD-WAN-TO-LAN-EXCLUDE permit tcp any 10.100.43.0 255.255.255.7
! itd device-group ITD-WAAS-GROUP probe icmp timeout 2 node ip 10.100.43.2 node ip 10.100.43.3
! Itd ITD-WAAS-SERVICE-LAN-TO-WAN device-group ITD-WAAS-GROUP exclude access-list ITD-LAN-TO-WAN-EXCLUDE access-list ITD-LAN-TO-WAN ingress interface vlan 100, vlan 101 !!Server VLANs. Make sure WAE-IP VLAN is not included (loop). failaction node reassign load-balance method src ip bucket 4 no shutdown
! Itd ITD-WAAS-SERVICE-WAN-TO-LAN device-group ITD-WAAS-GROUP access-list ITD-WAN-TO-LAN exclude access-list ITD-WAN-TO-LAN-EXCLUDE ingress interface Vlan 400 !! WAN facing VLAN failaction node reassign load-balance method dst ip bucket 4 no shutdown !
