09-11-2017 01:17 AM - edited 03-01-2019 09:31 AM
We currently have a pair of WAVE694s with AppNav controllers, and a futher two 694s as WAAS engines all in a single AppNav cluster. These are connected to some 3750x switches which use WCCP to divert traffic.
I'm looking at a Nexus based design for a new DC, and wondering what the best practice is for integrating WAAS with these switches - Nexus 9504 core, with some Nexus 9372s.
I've seen reference to using ITD with WAAS, but no specific detail - like here: https://blogs.cisco.com/enterprise/itd-intelligent-traffic-director
- Has anyone deployed ITD for WAAS?
- Is it a 'TAC supported' solution?
- What are other options on Nexus 9k - presumably just PBR?
Thanks!
Aaron
01-20-2020 01:31 PM
Hello!
Yes, same question here. We have 2x N9K-C93180LC-EX as DC Core with 7.0(3)I7(7) and WAAS WAE-694 with 6.4.3d software.
As DC-Core does not support WCCP, it looks like we need to go with ITD.
Will it work according to the config guide example Configuration Example: ITD as WCCP Replacement (Web-Proxy Deployment Mode)? Or anyone has an example config?
Thank you.
01-22-2020 06:32 AM - edited 01-22-2020 06:37 AM
Should look something like this but I am not sure.
! Send through WAE to remote sites ip access-list ITD-LAN-TO-WAN permit tcp any 10.100.16.0 0.0.0.255
! Dont send through WAE to remote sites ip access-list ITD-LAN-TO-WAN-EXCLUDE permit tcp 10.100.43.0 255.255.255.7 any
! Send through WAE from remote sites ip access-list ITD-WAN-TO-LAN permit tcp 10.100.16.0 0.0.0.255 any
! Dont Send through WAE from remote sites ip access-list ITD-WAN-TO-LAN-EXCLUDE permit tcp any 10.100.43.0 255.255.255.7
! itd device-group ITD-WAAS-GROUP probe icmp timeout 2 node ip 10.100.43.2 node ip 10.100.43.3
! Itd ITD-WAAS-SERVICE-LAN-TO-WAN device-group ITD-WAAS-GROUP exclude access-list ITD-LAN-TO-WAN-EXCLUDE access-list ITD-LAN-TO-WAN ingress interface vlan 100, vlan 101 !!Server VLANs. Make sure WAE-IP VLAN is not included (loop). failaction node reassign load-balance method src ip bucket 4 no shutdown
! Itd ITD-WAAS-SERVICE-WAN-TO-LAN device-group ITD-WAAS-GROUP access-list ITD-WAN-TO-LAN exclude access-list ITD-WAN-TO-LAN-EXCLUDE ingress interface Vlan 400 !! WAN facing VLAN failaction node reassign load-balance method dst ip bucket 4 no shutdown !
