WAAS OS upgrade issue
SK Ameen .
Hi ,
I upgarded the WAAS os from 4.2.3 to 4.3.3 on a WAE-274 . The "sh ver" ," sh flash" result shows the WAAS OS as 4.3.3. But in WAAS CM, under s/w version the device shows "4.3.3 {update failed} " error .
I also tried to reload the device after upgrading the WAAS OS but still Iam getting the same error message.
Please advice.
Hi Ameen,
What is the CM OS current version?
Have you upgraded your device through the CM or using copy ftp install commnad directly?
It would be a good step to check the syslog in the CM and the device you have upgraded, use "type syslog.txt" command to it.
Best regards,
Ahmad
