waas snmpv3 problems
draganskundric
I cannot get ciscoWorks works with waas devices using SNMPv3. Does anyone have any hint about this?
thanks
Hi Dragan,
I tested this in our lab and managed to get it working.
Here is what I had in the end:
Config
cdn-wave-574-1#sh run snmp
snmp-server user test test auth md5 **** priv ****
snmp-server group test v3 priv read SNMPv3 write SNMPv3 notify SNMPv3
snmp-server view SNMPv3 internet included
snmp-server view SNMPv3 system included
snmp-server view SNMPv3 cisco included
cdn-wave-574-1#
Once I set this up, I was able to snmpwalk to my WAE:
Snmpwalk results
nfournie@nfournie-laptop:~$ snmpwalk -v 3 -u test -l authPriv -a MD5 -A cisco12345 -x DES -X cisco12345 cdn-wave-574-1 system
SNMPv2-MIB::sysDescr.0 = STRING: Cisco Wide Area Application Services Software Hardware Version: oe574-4.3.1.6
Cisco Wide Area Application Services (universal-k9) Software Release 4.3.1 (build b6 Nov 13 2010)
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.985
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (25694500) 2 days, 23:22:25.00
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING: cdn-wave-574-1.cisco.com
SNMPv2-MIB::sysLocation.0 = STRING:
SNMPv2-MIB::sysServices.0 = INTEGER: 72
Comparing my config to yours, I see that the view is missing in yours. As I believe that if no view is defined, access will be denied by default, could you create a view that would allow access to your user group and see if it helps?
Nicolas
6 Replies 6
Nicolas Fournier
Hi Dragan,
With which part of Cisco Works are you trying to access the WAE? RME?
Are you able to snmpwalk the WAE from your LMS host?
If so, if you can share your SNMP config, maybe we could see if there is anything wrong with it.
Nicolas
I am trying to use RME, here is the config
snmp-server enable traps config
snmp-server enable traps alarm raise-critical
snmp-server enable traps alarm clear-critical
snmp-server enable traps alarm raise-major
snmp-server enable traps alarm clear-major
snmp-server enable traps alarm raise-minor
snmp-server enable traps alarm clear-minor
snmp-server enable traps entity
snmp-server enable traps snmp authentication
snmp-server enable traps snmp cold-start
snmp-server enable traps snmp linkup
snmp-server enable traps snmp linkdown
snmp-server enable traps event
snmp-server host 5.5.5.5 cworks v3  priv
snmp-server user cworks cw remote abc1234567 auth md5 **** priv ****
snmp-server group cw v3 priv
-)) mybe you could send me an working config if you have it
Hi Dragan,
Don't you have any community configured on your RME setup?
Maybe you could check the RME logs to see if it tells you why the import of the WAE fails?
Nicolas
I have. Can we please concentrate on waas snmpv3 config? Do you think this is ok or not?
Hi Dragan,
Config
cdn-wave-574-1#
Snmpwalk results
Nicolas
that's it. thanks
