WAE 512 Step-by-Step Replacement
andrels
Folks,
I will have to replace an WAE512 located in a branch office in a few days.
Would you guys recommend some good step-by-step to accomplish this task sucessfully?
Thanks in Advance,
sachinga.hcl
Level 4
Level 4
Hi Andrel,
Your information is not complete.
Would u plz tell with which device you are going to replace the WAE 512.
Is it replacement or removal.
Kindly clear this.
Sachin garg
This is an Inline solution for the WAE512.
Topology looks like this:
(Router)---(WAE)---Switch
This is replacement.. Control manager shows this WAE as down.
