WAE-674 Sequence Number with Checkpoint
Hi all,
we have a Checkpoint FW and two WAE-674 in our Branch. In a other Branch we have a WAE-574. We have a Problem with the Sequence Number on our FW when we use the Transparent Mode.
Is this Problem fixt or have another people the same Problem ?
I have a Test Installation in our Lab with the same Hardware. We have test the direct mode but this dosn't also work. When i have enable this mode i can't connect from the Central Manager to the WAE in the "other" Branch.
Without the FW the transparent Mode Work's fine.
Andreas
Daniel Laden
Level 4
Level 4
I assume the checkpoint is between the two sites.
You can turn off tcp scrubbing and sequence checking on the Checkpoint (they're both on by default). To make this happen you need to enable Checkpoint's Wire Mode.
Are these devices inline or using wccp. If inline, you will need to assign an IP address to the interface to be used for directed mode.
-Dan
