WAVE-274-K9 and WAE-512-K9 as CM ?
gnijs
Level 4
Level 4
1) Can the WAVE-274-K9 device be configured as a WAAS Central Manager off-the-shelf ?
2) Same for WAE-512-K9 device ?
regards,
Geert
dstolt
Geert,
For the CM functionality in WAAS 4.1.x, you need the enterprise license installed, then you can configure the CM role on the device.
274 can support around 125 WAEs
512-1GB can support 500 WAEs
512-2GB can support 1000 WAEs.
Hope that helps,
Dan
Thanks Dan.
Only thing is: the WAVE comes with Enterprise license by default (for a very good price). For the WAE, it needs to be added seperatly.
can you send me any document where you found it?
"274 can support around 125 WAEs
512-2GB can support 1000 WAEs. "
Thanks a lot,
