Wave 294 not showing in central manger ver 5.1
FROM WAVE able to ping cm but not showing in cm dashboard
Sent from Cisco Technical Support Android App
Jan Rockstedt
CMA 5.01 not 5.1?
I see my wave 294 in cma 5.01
Jan
yes my cm and wave both are 5.0.1
able to ping cm from wave but in cm dash board not showing wave
With 'not showing' do you mean: not visible at all or not active and alive?
What happens if you try a deregister force on the wave and try to do an identity recovery afterwards?
Best regards, Peter
