wccp v2 on a Cisco 6513 and Squid
cornerstonesd
I have a cisco 6513 configured to use wccp v2 with a RedHat AS5 server running Squid 2.6 using L2 redirection. On the squid server I have defined the wccpv2 router and set the assignment to "mask". ON the 6513 I have applied the following commands...
ip wccp web-cache
ip wccp version 2
ip wccp web-cache redirect-list 110 group-list 10
(under the inside vlan interface I used the following command)
ip wccp web-cache redirect in
They seem to see each other judging by the debug output...
--- debug clip ---
Aug 7 20:02:12 UTC: WCCP-EVNT:S00: Here_I_Am packet from 10.184.196.241 w/bad rcv_id 00000000
Aug 7 20:02:12 UTC: WCCP-PKT:S00: Sending I_See_You packet to 10.184.196.241 w/ rcv_id 000143AE
Aug 7 20:02:17 UTC: WCCP-PKT:S00: Sending Removal_Query packet to 10.184.196.241w/ rcv_id 000143AF
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_change_router_view: S00
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_change_router_view: deallocate rtr_view (24 bytes)
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_change_router_view: allocate hash rtr_view (1560 bytes)
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_change_router_view: rtr_view_size set to 24 bytes
Aug 7 20:02:22 UTC: WCCP-EVNT:S00: Built new router view: 0 routers, 0 usable web caches, change # 000050DD
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_copy_wc_assignment_data: enter
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_copy_wc_assignment_data: allocate orig mask info (28 bytes)
Aug 7 20:02:22 UTC: WCCP-EVNT:wccp_copy_wc_assignment_data: exit
--- debug clip ---
It is not working however and the only apparent error is the "bad rcv_id" sent by the squid server.
What am I missing?
The IOS on the router is 12.2(18)SXF6 (s72033-ipservicesk9-mz.122-18.SXF6.bin)
wong34539
Level 6
Level 6
To display WAE WCCP statistics, use the show statistics wccp EXEC command.
show statistics wccp gre
GRE Displays WCCP generic routing encapsulation packet-related statistics.
