web load balancing
Hi there,
Cisco used to have css11500.
I can't find anything about current load balancers , especially for web servers
Do they still have it or it's being slightly changed?
CSSs are still their Appliance type LoadBalancer. It will soon be replaced b ACE Appliance.
Other LoadBalancers Cisco has to offer (CSM and ACE) are Module based (goes into CAT 6500 chassis).
Syed
thank you for your reply.
What is the best solution based on your experience if you have any to balance web servers, let say 3 for now.
You can go for the CSS11501 with or without ssl acceleration which depends whether you wish to offload SSL or not.
sathappan.s
