What is the maximum throughput for a 7341 and 7371?
jkeeffe
Level 2
Level 2
I found the data sheet that describes the size of the two boxes, and lots of other statistics, but no throughput stats. Is the main difference between the 7341 and 7371 the memory and hard drive cache size?
Our data center headend WAE will be L2 connected to a redundant pair of 6506 distribution switches with gig uplinks.
I need to make sure I get the right device that can handle gig throughput of redirected accelerated traffic . Will the 7371 handle that?
2 Accepted Solutions
sachinga.hcl
Level 4
Level 4
Hi Jim,
WAE-MODEL WAN-SUPPORTED LAN-THROUGHPUT-MAXIMUM TFP-ONLY-THROUGHPUT MAXIMUM-CONNECTIONS-CAPACITY(TCP)
WAE-7341 310 MBPS 600 MBP 800 MBPS 12000
WAE-7371 1 GBPS >1 GBPS > 1 GBPS 50000
MAXIMUM SUPPORTED PEERS PER WAE
APPLIANCE CONCURRENT-PEERS
7341 200
7371 400
The WAE-7341 and WAE-7371 appliances provide the following features and benefits:
Feature Benefit
Hardware RAID-5
Allows the appliance to continue operating with one drive in a non-functioning state for increased reliability.
Provides increased logical disk capacity.
Disk hot-swap capability
No downtime when removing or installing hard disk drives.
64-bit kernel
Allows a larger memory footprint for the TCP Proxy application and increases the number of concurrent optimized connections for increased scalability and performance.
300-GB SAS1 hard disk drives
4 x 300 GB in the WAE-7341
6 x 300 GB in the WAE-7371
Disk monitoring
Allows you to monitor, analyze, and control the RAID status through the CLI and view basic disk status in the RAID from the Central Manager GUI.
1 SAS = Serial Attached SCSI
FOR MORE INFO ON HARDWARE SPECIFICATION PLZ CLICK FOLLOWING URL:
http://www.cisco.com.ru/en/US/docs/app_ntwk_services/waas/wae/installation/7341-7371/guide/7300spec.html
FOR Global Price List - Effective: 20-apr-2009 KINDLY REFER URL:
http://price.c-group.com.ua/cisco/-0002.html
PLZ RATE
KIND REGARDS.
SACHIN GARG
Kindly follow the below link and download pdf and see page no 12 for optimized tcp connections and 19 for your throughput answers for WAE-7341 and WAE-7371 appliances .
http://www.cisco.com/web/CA/pdf/waas_kanata_customer_technical_RZ11092007.pdf
Also refer this book chapter 2
Deploying Cisco Wide Area Application Services By Zach Seils, Joel Christner, Cisco press
http://books.google.co.in/books?id=tk1inCVI8fUC&pg=PA47&lpg=PA47&dq=cisco+Cisco+WAE-7341+LAN+throughput&source=bl&ots=81qTSv2mlV&sig=0iqWBkkQwPr7IuoSAiX8TzpdILg&hl=en&ei=EsgKSqbxHJiYkQWRiP2sCw&sa=X&oi=book_result&ct=result&resnum=4
Kind Regards,
Sachin
sachinga.hcl
Level 4
Level 4
Hi Jim,
7341 200
7371 400
Feature Benefit
Hardware RAID-5
64-bit kernel
Disk monitoring
PLZ RATE
KIND REGARDS.
SACHIN GARG
Kind Regards,
Sachin
Hi Jim,
Thaanks for your kind double-rating . you are amazing. No words for thanks.
