Why are two service group numbers required for WCCP
AJAZ NAWAZ
Level 5
Level 5
Hi.
Two service group identifiers are required for WCCP redirection for TCP and second one is automatically set for UDP even if it is explicity specified?.
for example:
ip wccp 41 redirect-list ....
ip wccp 42 redirect-list ..
Is my understanding correct on this?
thank you
2 Accepted Solutions
I have found that every single service you want to configure are UDP services. As far as I can see on the Silverpeak configuration guide it may use UDP or TCP ports. The WCCP configuration must match the services on both devices, the WCCP Router and the Cache Engine.
Please refer to the configuration Guide you may find at the link listed below:
http://www.silver-peak.com/sites/default/files/userdocs/network_deployments_r5-2_revk_oct2012.pdf
For further queries it would be recommended for you to get in touch with the Silverpeak TAC so they can explain if is really needed the TCP along with the UDP services to be configured on the devices.
My point of view is that you only need to configure the services to match on both sides whether you are using UDP or TCP services, in other words you need to configure the same service on the router than the services configured on the Silverpeak. As you are using 4 different protocols, you will need to configure 4 services on the Router and on the Silverpeak appliance.
Here is an example:
Router config:
cisco2811(config)# ip wccp 53 redirect-list 101
cisco2811(config)# ip wccp 54 redirect-list 101
Silverpeak config:
8 Replies 8
Juan Leon
Hi Ajaz,
This is Juan. I have been reviewing this and the ports mentioned on your post are for UDP. The 42 says is used for ARPA (ARPA Host Name Server Protocol) or even for WINS (Windows Internet Name Service) while the 41 is used for graphics or Trojans. For the port 41 I have found this link:
http://www.speedguide.net/port.php?port=41
As far as I understand, WCCP uses services for the traffic being redirected to the cache/proxy engine and the same service numbers must be configured on the cache engine since they work as identifiers for the traffic in question.
Now depending on the appliance you are working with, it will have the default WCCP service identifier per protocol.
For example Cisco WAAS uses services 61 and 62 which are the promiscuous services for TCP.
Ironport uses service 80 for web-cache and the services 70 for HTTP and 0 for HTTPS.
At least on Cisco Routers when you configure WCCP the router will not dynamically generate any service. The administrator must always to configure which are the services they want to enable for WCCP redirection.
For example you may configure this on a Cisco Router:
ip wccp 61
ip wccp 62
ip wccp web-cache
ip wccp 70
ip wccp 0
This is the very basic configuration, I am skipping the detail where the redirection statement must be placed on the interfaces playing redirection here, this is that the interfaces where the insteresting traffic is being received must be configured with the ip wccp redirect .
This is for Cisco routers, that is why I am telling that depending on the platform you are using as WCCP router and which type of cache engine you are using the services must be configured using the same service identifier/number. At least on the WCCP routers there are no services created dynamically, the net admin must configure them. There may be cache engines that dynamically creates a service for WCCP, but that is platform dependent.
Juan Leon
Hi, here is a configuration example for a Cisco Router and a Bluecoat proxy for the Web-cache service, please notice that the same service was configured on both devices, otherwise the redirection will not occur:
Standard HTTP Redirection Using a Security Password
A simple eight-character password is configured within the router. This password must match the password configured within the ProxySG.
Router Configuration
The following example enables standard HTTP traffic redirection on a WCCP version 2-capable Cisco router.
Router(config)# ip wccp web-cache password 29gy8c2
Router(config)# interface ethernet 0
Router(config-if)# ip wccp web-cache redirect out
Router(config-if)# end
ProxySG Configuration
To enable the standard WCCP version 2 service group within the ProxySG, the following configuration file could be loaded.
# Enable WCCP to allow WCCP protocol communication between
# the ProxySG Appliance and the home router.
wccp enable
# By default, the WCCP version 2 protocol is assumed. An
# explicit “wccp version 2" command could be specified
# here.
service-group web-cache
# Specify the address for the router.
home-router 90.0.0.90
# Network interface 0 will participate.
interface 0
password 29gy8c2
end
Are you referring to WCCP for WAAS?
If so you are correct two service groups are defined one which hashes on source ip and the other hashes on destination ip.
The default WAAS config for WAAS would be:
wccp router-list 1 14.110.3.129
wccp tcp-promiscuous service-pair 61 62
router-list-num 1
enable
exit
This means you have to globally define 61 and 62 on your router and then specific which interfaces you want to redirect on and in which direction:
pdi-2821-rtp#sh run
Building configuration...
hostname pdi-2821-rtp
ip wccp 61
ip wccp 62
interface GigabitEthernet0/0.1
description Client-LAN
encapsulation dot1Q 500
ip address 14.110.3.113 255.255.255.240
ip wccp 61 redirect in
ip flow ingress
interface GigabitEthernet0/0.2
description WAVE-574
encapsulation dot1Q 600
ip address 14.110.3.129 255.255.255.240
ip helper-address 10.86.77.7
ip flow ingress
interface GigabitEthernet0/1
description WAN Link
ip address 14.110.3.62 255.255.255.252
ip wccp 62 redirect in
ip flow ingress
ip flow egress
duplex full
speed auto
Note, that WCCP services for WAAS are TCP only (see keyword tcp-promiscuous).  When WCCP services are negotiated between the router and WAAS device it signals that it's interersted in TCP packets only (all TCP packets).   Thus, UDP traffic will never be redirected to WAAS (and you would not want to since it does not optimize UDP).
You can also configure any service-pair numbers if 61/ 62 happen to be in use by another WCCP service.  For example:
wccp tcp-promiscuous service-pair 41 42
router-list-num 1
enable
exit
Just then make sure you configure this service pair and redirect interfaces appropriately on your WCCP router (14.110.3.129 in this case).
hi guys
Cisco one-armed set-up with Silverpeak NX series appliance and the service IDs I would like to query are 51,52,53,54
thank for replies so far !
I have been reading about Silverpeak and I see that you requiere to set up an UDP service on the appliance and on the Cisco Router, here is the link:
http://www.exclusive-networks.it/wp-content/uploads/silver-peak-NX-series.pdf
Now we need to investigate why Silverpeak needs the UDP service configured, that is why I have mentioned that the configuration is platform dependent. For example Cisco WAAS only needs TCP services 61 and 62 configured on the router and on the WAE appliance. With Bluecoat it only needs that the web-cache service to be configured on the appliance and on the WCCP router.
Let me try to find out why does Silverpeak needs a UDP service configured along with WCCP.
Here is an example:
Router config:
Silverpeak config:
Juan Leon
I think it was important that we all get an understanding around service IDs, because to be totally frank, its not that very well documented.
many thanks for your investigation and replies !
