Will ACE work with DHCP request and loadbalancing
sajism220
We are facing an issue with ACE-DHCP load balancing,we have some x vlan ,which is behind FWSM and CNR server server is in vlan x.The IP is 192.x.x.x which is behind FWSM,and ace VIP is 192.x.x.x.
The real problem is when we bypass the ACE from MSFC..the client DHCP request is going to CNR and picking up the IP,but when we revert back the ACE,and the request is not going to CNR,client are getting limited connectvity.
here is the ACE config
probe udp CNRProbe
port 67
interval 30
faildetect 2
passdetect interval 30
passdetect count 2
rserver host CNR-1
ip address 192.x.x.62
inservice
rserver host CNR-2
ip address 192.x.x.63
inservice
serverfarm host CNR-SF
failaction purge
rserver CNR-1
inservice
rserver CNR-2
inservice
class-map match-all DHCP-VIP
2 match virtual-address 192.x.x.60 udp eq 67
class-map type management match-any REMOTE-ACCESS
2 match protocol icmp any
policy-map type management first-match REMOTE-MGMT
class REMOTE-ACCESS
permit
policy-map type loadbalance first-match DHCP-Server
class class-default
serverfarm CNR-SF
interface vlan xx
description clientside
bridge-group xx
no normalization
no icmp-guard
access-group input OSS
access-group output OSS
service-policy input REMOTE-MGMT
service-policy input Serverfarm-Policy
no shutdown
interface vlan y
description serverside
bridge-group XX
no shutdown
interface bvi 5
ip address x.x.x.x
alias x.x.x.x
peer ip address x.x.x.x
no shutdown
ip route 0.0.0.0 0.0.0.0 x.x.x.x
Will we able to loadbalance the DHCP server by ACE in real time? coz DHCP using 2 ports,will ace can do ? We used to assign CNR VIP to user vlan..any who had experence on this kind of problem pls share,that will be gratefull.
Saji k.s
Gilles Dufour
you should sniff the traffic from ACE tengig interface using a NAM or a PC.
See what traffic the client sends and what ACE does with it.
From there we can figure it out if there is something we can add to the config to make it work.
Gilles.
I tried to do the same,but I could not able to find the port which your talking about,can you specifie bit more,that will be gratefull.Is this logical port of ACE.
