WS-SUP720-3B SP DRAM requirement for ACE30
Akhtar Samo
Last month I was reviewing following Cisco document, in which Cisco mentioned that ""To avoid possible memory fragmentation in the forwarding information base (FIB), Cisco recommends that the switch processor (SP) DRAM to a minimum of 1 GB ""
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_1_0/installation/note/ace30inote.html
Since this document has been revised in Oct 2011 and, I can't no more find the above memory recommendations.
I want know if any one using WS-SUP720-3B with IOS SXI6 and Cisco ACE30 has gone for upgrading the SP DRAM from 512MB(default) to 1GB ?
Akhtar
asharmav
Hi Akhtar
No it is not required, and no longer recommended. This was temporarily listed in the release notes, based on a DDTS which was later found to have a different root cause. Thus we were able remove the line in the release notes.
So there is no need to upgrade Sup memory to migrate to ACE30.
Hope this helps.
Abhi
