09-14-2011 01:50 PM
ok i just upgraded to 1.0.3.4 however my custom ntp server settings changed from
uk.pool.ntp.org
to
uk.pool.config.ntp.org
upon reboot.
09-14-2011 02:41 PM
Thanks Simon! This is just .... embarassing . Although this is a beta version but we'll fix this and come up w/ another fw release.
09-14-2011 03:09 PM
Simon,
I wonder if the Web GUI will allow you to reconfigure the Cutom NTP Server to the correct value, and if the correct value will stick after another reboot? Basically I am trying to determine if the issue has a valid workaround.
Thanks.
09-14-2011 04:04 PM
Tekai, We'd tried this in the lab. After corrected the value, it'll change again after every reboot.
09-14-2011 10:58 PM
Oh that's not good!
09-14-2011 10:58 PM
Tekai, I changed it back but have not rebooted so far. I will do this sometime this morning from work. The only reason I noticed was the date/time in the logs again start to log at jan 01.
I had Bonjour enabled but Bonjour entries still insist on reporting Jan 01 in the default log even though date is correct. I disabled bonjour and still bonjour logs entries????
Btw I have set my default log to report everything possible so that I can see what is failing etc. If you guys need a copy of my config again let me know.
09-21-2011 04:38 PM
is there any update on the ntp issue? possibly a fix? this is so annoying that it re-adds the ".config." to the ntp host name on reboot.
09-21-2011 04:43 PM
For this issue, we 're actively working on it. Dev team indicated that this only happen to your specific ntp server name of "uk.pool.ntp.org". If possible, please try w/ another ntp server (*temporary* until we came out w/ another fw).
09-21-2011 04:54 PM
i picked another UK ntp server
uk.ntp.f-box.org
oh and guess what!
uk.config.ntp.f-box.org after a reboot! lol
09-21-2011 04:57 PM
LOL! You've done enough damage for today. I think you deserve to go to bed. Sweet dream!
09-22-2011 09:52 AM
Simon,
I was told that you will see this problem occurred when configured ntp server that named with "ntp" characters included. So please try again w/ another ntp server that excluded "ntp".
Don
09-22-2011 01:35 PM
lol you can't have an ntp server name with ntp in it? Someone's pulling your leg. Guess we better change about 90% of ntp server names then to fix that issue
