03-29-2011 05:57 PM
The RV110W is working fine. I've tried to connect 4 different PC laptops, 1 Macbook Pro, 1 iPhone, 1 iPod Touch to it, but once I get to another room in the home, which is approx. 30-40 feet away from the RV110W, the signal is down to 1 bar and the connection comes and goes. This seems like a very short range compared to different routers I've used before. There are 3 walls between this room and where the router is, but as stated before, other routers I've used in the past had no problems with this.
03-30-2011 01:04 PM
Thanks Kevin and welcome to the forum!
There's report of weak wifi signal on this router. I just don't know how severe that is. I'll send your finding to the team for further checking.
regards,
Don
03-31-2011 09:48 AM
Hi Kevin,
Have you have a chance to upgrade your router to 1.0.1.0? Please try to upgrade and let me know if wifi problem still persists.
Thanks!
03-31-2011 09:57 AM
Hi Don,
I just upgraded to the new firmware last night. Testing it the next few days to see if the problem is fixed. Will let you know.
Thanks.
04-13-2011 10:01 AM
Hi Kevin,
Did you try chaning the settings on the router based on Eric's feedback?
How is the range performing for you over the last couple of days?
Chris
04-13-2011 03:57 PM
Hi Chris,
Yes, I changed the settings based on Eric's recommendations. It seems to have made a slight improvement. The signal is still weak (at 1 bar out of 4) from a distance of 30-40 feet. I'm not losing connection as much as before, but still lose connection every once in a while (but not nearly as much as before).
Kevin
