Time issue with new Firmware 1.0.2.4
linksysinfo
Level 4
Level 4
Hvae got an isse with the RV220W.  when i reboot the router from the adminitration panel the time is reset to 1 Jan 2000
NTP default or my own ntp servers dont seems to work.
anyone else confirm this?
Regards Simon
7 Replies 7
linksysinfo
Level 4
Level 4
I'm using uk.pool.ntp.org and i can ping this from the diagnostics ping field.
on looking at the logs now it looks like there are some major issues!
Sat Jan  1 00:02:34 2000(UTC) [rv220w][System][PLATFORM] profile default doesnt exist.
Sat Jan  1 00:02:34 2000(UTC) [rv220w][System][PLATFORM] Deletion of EAP Profile failed
Sat Jan  1 00:02:49 2000(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 1 failed. status=-1
Sat Jan  1 00:02:49 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
Sat Jan  1 00:02:51 2000(UTC) [rv220w][System][PLATFORM] IPv6 not configured on the interface
Sat Jan  1 00:02:53 2000(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 2 failed. status=-1
Sat Jan  1 00:02:54 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=2
Sat Jan  1 00:02:54 2000(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 1 failed. status=-1
Sat Jan  1 00:02:54 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
Sat Jan  1 00:02:54 2000(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 3 failed. status=-1
Sat Jan  1 00:02:54 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=3
Sat Jan  1 00:03:06 2000(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 2 failed. status=-1
Sat Jan  1 00:03:06 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=2
Sat Jan  1 00:03:20 2000(UTC) [rv220w][System][PLATFORM] dbRecordValueGet failed for ProfileName column
Sat Jan  1 00:03:20 2000(UTC) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Sat Jan  1 00:03:54 2000(UTC) [rv220w][System][FIREWALL] fwPPTPGenericRules.c: inet_aton failed
Sat Jan  1 00:06:39 2000(UTC) [rv220w][System][NTP] dbRecordValueGet failed for dstStartMonth column
Sat Jan  1 00:06:39 2000(UTC) [rv220w][System][NTP] Error in executing DB update handler
Sat Jan  1 00:06:39 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (23, UMI_CMD_DB_UPDATE(4)) failed. table=ntp row=1
Sat Jan  1 00:06:50 2000(UTC) [rv220w][System][NTP] dbRecordValueGet failed for dstStartMonth column
Sat Jan  1 00:06:50 2000(UTC) [rv220w][System][NTP] Error in executing DB update handler
Sat Jan  1 00:06:50 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (23, UMI_CMD_DB_UPDATE(4)) failed. table=ntp row=1
Sat Jan  1 00:07:03 2000(UTC) [rv220w][System][NTP] dbRecordValueGet failed for dstStartMonth column
Sat Jan  1 00:07:03 2000(UTC) [rv220w][System][NTP] Error in executing DB update handler
Sat Jan  1 00:07:03 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (23, UMI_CMD_DB_UPDATE(4)) failed. table=ntp row=1
Sat Jan  1 00:07:40 2000(UTC) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 4 failed. status=-1
Sat Jan  1 00:07:40 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=4
Sat Jan  1 00:14:57 2000(UTC) [rv220w][System][NTP] dbRecordValueGet failed for dstStartMonth column
Sat Jan  1 00:14:57 2000(UTC) [rv220w][System][NTP] Error in executing DB update handler
Sat Jan  1 00:14:57 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (23, UMI_CMD_DB_UPDATE(4)) failed. table=ntp row=1
Sat Jan  1 00:17:07 2000(UTC) [rv220w][System][NTP] dbRecordValueGet failed for dstStartMonth column
Sat Jan  1 00:17:07 2000(UTC) [rv220w][System][NTP] Error in executing DB update handler
Sat Jan  1 00:17:07 2000(UTC) [rv220w][System][EVTDSPTCH] umiIoctl (23, UMI_CMD_DB_UPDATE(4)) failed. table=ntp row=1
Sat Jan  1 00:02:34 2000(UTC) [rv220w][Kernel][KERNEL] CVMSEG size: 2 cache lines (256 bytes)
Sat Jan  1 00:02:34 2000(UTC) [rv220w][Kernel][KERNEL] CPU revision is: 000d0601
Sat Jan  1 00:02:34 2000(UTC) [rv220w][Kernel][KERNEL] Determined physical RAM map:
Sat Jan  1 00:02:34 2000(UTC) [rv220w][Kernel][KERNEL]  memory: 0000000007800000 @ 0000000000700000 (usable)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Built 1 zonelists.  Total pages: 30276
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Primary instruction cache 32kB, virtually tagged, 4 way, 64 sets, linesize 128 bytes.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Primary data cache 16kB, 64-way, 2 sets, linesize 128 bytes.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] PID hash table entries: 512 (order: 9, 4096 bytes)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Using 400.000 MHz high precision timer.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Inode-cache hash table entries: 8192 (order: 4, 65536 bytes)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Calibrating delay using timer specific routine.. 800.39 BogoMIPS (lpj=1600786)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Mount-cache hash table entries: 256
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Checking for the multiply/shift bug... no.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Checking for the daddi bug... no.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Checking for the daddiu bug... no.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Enabling Octeon big bar support
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] PCI Status: PCI 32-bit
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] IP route cache hash table entries: 1024 (order: 1, 8192 bytes)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] TCP established hash table entries: 4096 (order: 4, 65536 bytes)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] /proc/octeon_perf: Octeon performace counter interface loaded
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Total HugeTLB memory allocated, 0
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] RAMDISK driver initialized: 1 RAM disks of 500000K size 1024 blocksize
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] GACT probability NOT on
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Mirror/redirect action on
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] u32 classifier
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL]     Performance counters on
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL]     Actions configured
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] ip_conntrack version 2.4 (480 buckets, 3840 max) - 352 bytes per conntrack
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] ip_conntrack_rtsp v0.6.21 loading
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] ip_nat_rtsp v0.6.21 loading
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] netfilter PSD loaded - (c) astaro AG
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] ipt_time loading
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Bootbus flash: Setting flash for 32MB flash at 0x1dc00000
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL]  Amd/Fujitsu Extended Query Table at 0x0040
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] BOOT BUS: Address decode error
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] cavium-ethernet: Cavium Networks Octeon SDK version 1.7.3, build 264
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Register the sysctl for hardware offload succeed 0
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Register the sysctl for flow cache succeed
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Register the sysctl for brcm Tag succeed
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Register the sysctl for vlan enabled succeed
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Pool 0 size 2048 No 1024
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Pool 1 size 128 No 1024
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Pool 3 size 128 No 10240
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] global cache allocation start 0
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Ipforward global cache allocation sucessfull
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Registerd the sysctl for IMP port status
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Registerd the sysctl for 802.1x enabled port
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Registerd the sysctl for blocking non EAP packets status
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Interface 0 has 3 ports (RGMII)
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] 999
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] 1002
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] 1040
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] 1042
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] port ko 0
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] port ko 1
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] port ko 2
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] led module init...
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] umi: module license 'unspecified' taints kernel.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] eth0: 1000 Mbps Full duplex, port  0, queue  0
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] eth1: 1000 Mbps Full duplex, port  1, queue  1
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] PF_key: Initialized Security Policy Database.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] IPsec: Initialized Security Association Processing.
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] BUG: at kernel/softirq.c:138 local_bh_enable()
Sat Jan  1 00:02:35 2000(UTC) [rv220w][Kernel][KERNEL] Call Trace:[][][][][][][][][][][][
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] Intializing the 8021P-DSCP Remark Module
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] Registerd the sysctl for _8021p task IMP port<6>registering backend engine with xlr8Nat framework
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] Registerd the sysctl reboot status
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] PCI: Enabling device 0000:00:03.0 (0000 -> 0002)
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] vap0: Broadcom BCM432b 802.11 Wireless Controller 5.60.120.9
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] ip_conntrack_pptp version 3.1 loaded
Sat Jan  1 00:02:36 2000(UTC) [rv220w][Kernel][KERNEL] ip_nat_pptp version 3.0 loaded
Sat Jan  1 00:02:40 2000(UTC) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan  1 00:02:43 2000(UTC) [rv220w][Kernel][KERNEL] HTB: quantum of class 10002 is big. Consider r2q change.
Sat Jan  1 00:02:43 2000(UTC) [rv220w][Kernel][KERNEL] HTB: quantum of class 10005 is big. Consider r2q change.
Sat Jan  1 00:07:43 2000(UTC) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan  1 00:02:34 2000(UTC) [rv220w][Local0-wireless][PNAC_USR] Error from pnacPhyPortDestroy: port not configured
Sat Jan  1 00:02:34 2000(UTC) [rv220w][Local0-wireless][PNAC_USR] pnacUmiPhyPortDestroy: Failed to destroy the port
2000-01-01 00:00:37: [rv220w][IKE] INFO:  IKE started
I may need to do a full reset on this router now!
Regards Simon
ok guys I reset my RV220W which i did not really want to do, but it did fix the NTP issue, however there is an underlying issue still with time.
once you confirm the time is correct, goto
Adminitration > logging > logging policies, select your default log and edit. enable ALL feilds so you can see what the Router is doing.
then goto: Status > View logs. Clear Logs. once i clear the log a new log line appears.
Sat Jan  1 00:02:19 2000(GMT) [rv220w][Kernel][KERNEL] umi: module license 'unspecified' taints kernel.
now look at the date!  Jan 1 2000, yet the date on the router is correct!
Regards Simon
Once you have done that, reboot router, once it has rebooted login again and now read logs.  All reported log entries are now reported as Jan 1 2000 yet Time in the Time Settings reports the correct time.  I have posted again my logs.
Sat Jan  1 00:02:21 2000(GMT) [rv220w][System][FIREWALL] led off command execute: echo d0>/proc/led
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:_8021x op=18 row=1
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] ../../mgmt/8021xMgmt.c:DBUpdate event: Table: _8021x opCode:18 rowId:1
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] _8021xMgmtDBUpdateHandler: update received: Table: _8021x opCode: 18 rowId: 1
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] profile default doesnt exist.
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] Deletion of EAP Profile failed
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.11.1___
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 0 for LogicalIfName = LAN10
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=18 row=5
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:18 rowId:5
Sat Jan  1 00:02:22 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:23 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:18 rowId:5
Sat Jan  1 00:02:23 2000(GMT) [rv220w][System][NTP] Looking Up uk.pool.ntp.org
Sat Jan  1 00:02:24 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:networkInterface op=18 row=9
Sat Jan  1 00:02:24 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:18 rowId:9
Sat Jan  1 00:02:24 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][NTP] Looking Up uk.pool.ntp.org
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:18 rowId:9
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][PLATFORM] igmpMgmtDBUpdateHandler: update received: Table: networkInterface opCode: 18 rowId: 9
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][PLATFORM] igmpDisable: failed to disable IGMP proxy. IGMP proxy may not be running at all!
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][PLATFORM] igmpEnable: IGMP proxy enabled successfully
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][PLATFORM] Disabling Firewall Rule for DHCP Relay Protocol
Sat Jan  1 00:02:35 2000(GMT) [rv220w][System][PLATFORM] ddnsMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:18 rowId:9
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.12.1___
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 0 for LogicalIfName = LAN20
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=18 row=6
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:18 rowId:6
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:18 rowId:6
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:networkInterface op=18 row=10
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:18 rowId:10
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][NTP] Next DNS Retry after 1 min
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:18 rowId:10
Sat Jan  1 00:02:36 2000(GMT) [rv220w][System][PLATFORM] igmpMgmtDBUpdateHandler: update received: Table: networkInterface opCode: 18 rowId: 10
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] igmpDisable: failed to disable IGMP proxy. IGMP proxy may not be running at all!
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] igmpEnable: IGMP proxy enabled successfully
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] Disabling Firewall Rule for DHCP Relay Protocol
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] ddnsMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:18 rowId:10
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:dot11STA op=18 row=1
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 1 failed. status=-1
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=1
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:upnpVlanAssoc op=18 row=1
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: upnpVlanAssoc opCode:18 rowId:1
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:upnpVlanAssoc op=18 row=2
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: upnpVlanAssoc opCode:18 rowId:2
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:upnpVlanAssoc op=18 row=3
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: upnpVlanAssoc opCode:18 rowId:3
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] IPv6 not configured on the interface
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] RADVD stopped successfully
Sat Jan  1 00:02:37 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:system op=23 row=1
Sat Jan  1 00:02:38 2000(GMT) [rv220w][System][PLATFORM] [BONJOUR_DEBUG]: Getting the results of Sql Query: SELECT value FROM environment WHERE name='BONJOUR_DEFAULT_SERVICE_NAME'
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][PLATFORM] [BONJOUR_DEBUG]: Performing SqlQry : UPDATE bonjourDefaultServices SET textRecord = 'model=RV220W;deviceType=Router;deviceDescr=Wireless-N-VPN-Router;slaves=0;fmVersion=1.0.2.4;PIDVID=RV220W-A V01;MACAddress=C84C7540F0E4;serialNo=SER143001EV;
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][PLATFORM] [BONJOUR_DEBUG]: Performing SqlQry : UPDATE bonjourDefaultServices SET serviceID = 'RV220W'
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:dot11STA op=18 row=2
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 2 failed. status=-1
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=2
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -D webFltr 0.0.0.0___
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.10.1___
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 1 for LogicalIfName = LAN
Sat Jan  1 00:02:39 2000(GMT) [rv220w][System][FIREWALL] Restarting Firewall For LAN Address Update from 0.0.0.0:172.16.10.1
Sat Jan  1 00:02:40 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=1
Sat Jan  1 00:02:40 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:1
Sat Jan  1 00:02:40 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:41 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:1
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -D webFltr 172.16.10.1___
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.10.1___
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 1 for LogicalIfName = LAN
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=1
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:1
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:42 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:1
Sat Jan  1 00:02:44 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 1 for LogicalIfName = WAN1
Sat Jan  1 00:02:44 2000(GMT) [rv220w][System][FIREWALL] Restarting Firewall For WAN1 Address Update from 0.0.0.0:192.168.0.2
Sat Jan  1 00:02:44 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=2
Sat Jan  1 00:02:44 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:44 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:44 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:45 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -D webFltr 192.168.10.1___
Sat Jan  1 00:02:45 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.11.1___
Sat Jan  1 00:02:45 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 0 for LogicalIfName = LAN10
Sat Jan  1 00:02:45 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=5
Sat Jan  1 00:02:45 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:5
Sat Jan  1 00:02:46 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:46 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:5
Sat Jan  1 00:02:47 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -D webFltr 172.16.11.1___
Sat Jan  1 00:02:47 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.11.1___
Sat Jan  1 00:02:47 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 0 for LogicalIfName = LAN10
Sat Jan  1 00:02:47 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=5
Sat Jan  1 00:02:47 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:5
Sat Jan  1 00:02:47 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:48 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:5
Sat Jan  1 00:02:49 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -D webFltr 192.168.20.1___
Sat Jan  1 00:02:49 2000(GMT) [rv220w][System][FIREWALL] ____/pfrm2.0/bin/ipset -A webFltr 172.16.12.1___
Sat Jan  1 00:02:49 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 0 for LogicalIfName = LAN20
Sat Jan  1 00:02:49 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=6
Sat Jan  1 00:02:49 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:6
Sat Jan  1 00:02:49 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:50 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:6
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:dot11STA op=9 row=2
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 9 dot11STA 2 failed. status=-1
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=2
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 1 for LogicalIfName = WAN1
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][FIREWALL] Restarting Firewall For WAN1 Address Update from 0.0.0.0:192.168.0.2
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=2
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:51 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:52 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:NimfAFStatus op=23 row=1
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][PLATFORM] ddnsMgmtDBUpdateHandler:DBUpdate event: Table: NimfAFStatus opCode:23 rowId:1
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 1 for LogicalIfName = WAN1
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][FIREWALL] Restarting Firewall For WAN1 Address Update from 0.0.0.0:192.168.0.2
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=2
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:53 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:54 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:NimfAFStatus op=23 row=1
Sat Jan  1 00:02:54 2000(GMT) [rv220w][System][PLATFORM] ddnsMgmtDBUpdateHandler:DBUpdate event: Table: NimfAFStatus opCode:23 rowId:1
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:dot11STA op=18 row=2
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] /pfrm2.0/bin/bwLimitConfig /tmp/system.db 18 dot11STA 2 failed. status=-1
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][EVTDSPTCH] umiIoctl (18, UMI_CMD_DB_UPDATE(4)) failed. table=dot11STA row=2
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:resolverConfig op=23 row=2
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] dnsResolverConfigure: addressFamily: 10
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] dnsResolverConfigure: LogicalIfName: WAN1
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] dnsResolverConfigure: addressFamily: 2
Sat Jan  1 00:02:55 2000(GMT) [rv220w][System][PLATFORM] dnsResolverConfigure: LogicalIfName: WAN2
Sat Jan  1 00:02:56 2000(GMT) [rv220w][System][FIREWALL] restartStatus = 1 for LogicalIfName = WAN1
Sat Jan  1 00:02:56 2000(GMT) [rv220w][System][FIREWALL] Restarting Firewall For WAN1 Address Update from 0.0.0.0:192.168.0.2
Sat Jan  1 00:02:56 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=2
Sat Jan  1 00:02:56 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:56 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:02:56 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan  1 00:02:57 2000(GMT) [rv220w][System][PLATFORM] platformHandleDBUpdate:networkInterface op=23 row=3
Sat Jan  1 00:02:59 2000(GMT) [rv220w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:23 rowId:3
Sat Jan  1 00:03:00 2000(GMT) [rv220w][System][PLATFORM] options.pptpd file found
Sat Jan  1 00:03:00 2000(GMT) [rv220w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:23 rowId:3
Sat Jan  1 00:03:02 2000(GMT) [rv220w][System][PLATFORM] igmpMgmtDBUpdateHandler: update received: Table: networkInterface opCode: 23 rowId: 3
Sat Jan  1 00:03:02 2000(GMT) [rv220w][System][PLATFORM] igmpDisable: failed to disable IGMP proxy. IGMP proxy may not be running at all!
Sat Jan  1 00:03:02 2000(GMT) [rv220w][System][PLATFORM] igmpEnable: IGMP proxy enabled successfully
Sat Jan  1 00:03:02 2000(GMT) [rv220w][System][PLATFORM] Disabling Firewall Rule for DHCP Relay Protocol
Sat Jan  1 00:03:03 2000(GMT) [rv220w][System][PLATFORM] ddnsMgmtDBUpdateHandler:DBUpdate event: Table: networkInterface opCode:23 rowId:3
Sat Jan  1 00:03:03 2000(GMT) [rv220w][System][FIREWALL] Restarting Firewall [0]:[1] For WAN1
Sat Jan  1 00:03:03 2000(GMT) [rv220w][System][NIMF] Setting LED [0]:[1] For WAN1
Sat Jan  1 00:03:03 2000(GMT) [rv220w][System][NIMF] nimfNetIfaceTblHandler: unable to get LedPinId
Sat Jan  1 00:03:30 2000(GMT) [rv220w][System][NTP] Looking Up uk.pool.ntp.org
Sat Jan  1 00:03:32 2000(GMT) [rv220w][System][NTP] DayLightsaving: 0
Sat Jan  1 00:03:32 2000(GMT) [rv220w][System][NTP] Requesting time from uk.pool.ntp.org
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][NTP] Synchronized time with uk.pool.ntp.org
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][NTP] Timezone difference
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Disabling Attack Check for 0
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Attack Check for 1
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Attack Check for 2
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Attack Check for 3
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Attack Check for 4
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Attack Check for 5
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Attack Check for 6
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling ICSA Notification Item 0
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling ICSA Notification Item 1
Sun Aug 14 07:08:17 2011(GMT) [rv220w][System][FIREWALL] Enabling Management Access from Internet to port 443
Sun Aug 14 07:08:18 2011(GMT) [rv220w][System][FIREWALL] Disabling Source MAC Filtering
Sun Aug 14 07:08:18 2011(GMT) [rv220w][System][FIREWALL] Adding MAC Filter Policy for Block & Permit Rest
Sun Aug 14 07:08:18 2011(GMT) [rv220w][System][FIREWALL] Restarting Source MAC Address Policy
Sun Aug 14 07:08:18 2011(GMT) [rv220w][System][FIREWALL] Enabling DOS Attacks
Sun Aug 14 07:08:18 2011(GMT) [rv220w][System][NTP] Next Synchronization after 2 Hours
Sun Aug 14 07:08:20 2011(GMT) [rv220w][System][FIREWALL] Enabling Inter VLAN routing.
Sun Aug 14 07:08:20 2011(GMT) [rv220w][System][FIREWALL] inter vlan routing disabled
Sun Aug 14 07:08:20 2011(GMT) [rv220w][System][FIREWALL] fwPPTPGenericRules.c: inet_aton failed
Sun Aug 14 07:08:20 2011(GMT) [rv220w][System][FIREWALL] Disabling Firewall Rule for MSS packet marking
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Using 400.000 MHz high precision timer.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Inode-cache hash table entries: 8192 (order: 4, 65536 bytes)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Memory: 119040k/122880k available (3124k kernel code, 3788k reserved, 660k data, 1788k init, 0k highmem)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Calibrating delay using timer specific routine.. 800.39 BogoMIPS (lpj=1600786)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Mount-cache hash table entries: 256
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Checking for the multiply/shift bug... no.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Checking for the daddi bug... no.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Checking for the daddiu bug... no.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 16
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Enabling Octeon big bar support
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] PCI Status: PCI 32-bit
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 2
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Time: MIPS clocksource has been installed.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] IP route cache hash table entries: 1024 (order: 1, 8192 bytes)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] TCP established hash table entries: 4096 (order: 4, 65536 bytes)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] TCP: Hash tables configured (established 4096 bind 4096)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] TCP reno registered
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] /proc/octeon_perf: Octeon performace counter interface loaded
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Total HugeTLB memory allocated, 0
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] squashfs: version 3.0 (2006/03/15) Phillip Lougher
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] io scheduler noop registered
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] io scheduler cfq registered (default)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] RAMDISK driver initialized: 1 RAM disks of 500000K size 1024 blocksize
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] loop: loaded (max 8 devices)
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] PPP generic driver version 2.4.2
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] PPP BSD Compression module registered
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] MPPE/MPPC encryption/compression module registered
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 24
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] slram: not enough parameters.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] i2c /dev entries driver
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] GACT probability NOT on
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Mirror/redirect action on
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] u32 classifier
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL]     Performance counters on
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL]     Actions configured
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack version 2.4 (480 buckets, 3840 max) - 352 bytes per conntrack
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rsh: registering helper for port #0: 514/TCP
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rsh: helper match ip   0.0.0.0:514-0.0.0.0:0
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rsh: helper match mask 0.0.0.0:64512-0.0.0.0:64512
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rtsp v0.6.21 loading
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] net/ipv4/netfilter/ip_conntrack_rtsp.c: ip_conntrack_rtsp_init: port #0: 554
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_nat_rtsp v0.6.21 loading
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_tables: (C) 2000-2006 Netfilter Core Team
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ipt_account 0.1.7 : Piotr Gasid�o <quaker@barbara.eu.org>, http://www.barbara.eu.org/~quaker/ipt_account/
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] netfilter PSD loaded - (c) astaro AG
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ipt_time loading
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_tcp: registering helper for port #0: 111/TCP
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_tcp: helper match ip   0.0.0.0:0->0.0.0.0:111
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_tcp: helper match mask 0.0.0.0:0->0.0.0.0:65535
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_tcp: disabling Legato NetWorker support for port 0/TCP
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ipt_rpc: registering match [rpc] for;
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ipt_rpc:   port 111 (UDP|TCP);
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_udp: registering helper for port #0: 111/UDP
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_udp: helper match ip   0.0.0.0:0->0.0.0.0:111
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_rpc_udp: helper match mask 0.0.0.0:0->0.0.0.0:65535
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] TCP cubic registered
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 10
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] IPv6 over IPv4 tunneling driver
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 17
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] All bugs added by David S. Miller <davem@redhat.com>
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] serial8250: ttyS0 at MMIO 0x1180000000800 (irq = 42) is a 16550A
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] Bootbus flash: Setting flash for 32MB flash at 0x1dc00000
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL]  Amd/Fujitsu Extended Query Table at 0x0040
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
Sat Jan  1 00:02:24 2000(GMT) [rv220w][Kernel][KERNEL] number of CFI chips: 1
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 5 cmdlinepart partitions found on MTD device phys_mapped_flash
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Creating 5 MTD partitions on "phys_mapped_flash":
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 0x00000000-0x00080000 : "bootloader"
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 0x00080000-0x00680000 : "kernel"
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 0x00680000-0x01680000 : "rootfs"
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 0x01680000-0x01780000 : "data"
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 0x01780000-0x017a0000 : "bootload-env"
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] BOOT BUS: Address decode error
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Freeing unused kernel memory: 1788k freed
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] cavium-ethernet: Cavium Networks Octeon SDK version 1.7.3, build 264
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for hardware offload succeed 0
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for flow cache succeed
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for brcm Tag succeed
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Register the sysctl for vlan enabled succeed
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Pool 0 size 2048 No 1024
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Pool 1 size 128 No 1024
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Pool 3 size 128 No 10240
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] global cache allocation start 0
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Ipforward global cache allocation sucessfull
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for IMP port status
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for 802.1x enabled port
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for blocking non EAP packets status
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Interface 0 has 3 ports (RGMII)
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 999
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 1002
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 1040
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] 1042
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] port ko 0
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] port ko 1
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] port ko 2
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] led module init...
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] umi: module license 'unspecified' taints kernel.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 32
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] kernel UMI module loaded
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] eth0: 1000 Mbps Full duplex, port  0, queue  0
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] eth1: 1000 Mbps Full duplex, port  1, queue  1
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Initializing PF_KEY V2 Key Management socket interface.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] NET: Registered protocol family 15
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] PF_key: Started key_timehandler
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] PF_key: Initialized Security Policy Database.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: Initialized Security Association Processing.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] XLR8 IPSec Framework Initialized
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Software Backend Registered with XLR8 IPSec Framework
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Adding AH4 protocol processing.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Adding ESP4 protocol processing.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Adding IPCOMP4 protocol processing.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Adding packet sink.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] BUG: at kernel/softirq.c:138 local_bh_enable()
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Call Trace:[][][][][][][][][][][][
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] N_HDLC line discipline registered.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Intializing the 8021P-DSCP Remark Module
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl for _8021p task IMP port<6>registering backend engine with xlr8Nat framework
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] initializing flow cache database
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] initializing xlr8Nat engine queue
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] initializing xlr8Nat proc entries
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] xlr8Nat module loaded successfully
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Registerd the sysctl reboot status
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] PCI: Enabling device 0000:00:03.0 (0000 -> 0002)
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] vap0: Broadcom BCM432b 802.11 Wireless Controller 5.60.120.9
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Loading mii
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] using bcm switch bcm5395
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] privlegedID 4094 wanporttNo: 5
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] eth0: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] eth1: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: eth0
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] device eth0 entered promiscuous mode
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 1(eth0) entering learning state
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap0
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] device vap0 entered promiscuous mode
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 2(vap0) entering learning state
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap1
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] device vap1 entered promiscuous mode
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1) entering learning state
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap2
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] device vap2 entered promiscuous mode
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2) entering learning state
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] HTB: quantum of class 10001 is big. Consider r2q change.
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg20: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] Loading ifDev module
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg10: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] vap0: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] vap1: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] ip_conntrack_pptp version 3.1 loaded
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] ip_nat_pptp version 3.0 loaded
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] vap2: no IPv6 routers present
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: topology change detected, propagating
Sat Jan  1 00:02:25 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 1(eth0) entering forwarding state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: topology change detected, propagating
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 2(vap0) entering forwarding state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1) entering forwarding state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] manufacturingCo uses obsolete (PF_INET,SOCK_PACKET)
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2) entering forwarding state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device eth0 left promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 1(eth0) entering disabled state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: add 33:33:ff:40:f0:e4 mcast address to master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: del 33:33:ff:40:f0:e4 mcast address from vlan interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: del 33:33:ff:40:f0:e4 mcast address from master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: eth0.1
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device eth0.1 entered promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device eth0 entered promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 1(eth0.1) entering learning state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device vap0 left promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 2(vap0) entering disabled state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap0
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device vap0 entered promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 2(vap0) entering learning state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device vap1 left promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1) entering disabled state
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: add 33:33:ff:40:f0:e9 mcast address to master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:ff:40:f0:e9 mcast address from vlan interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:ff:40:f0:e9 mcast address from master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap1.1
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device vap1.1 entered promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] device vap1 entered promiscuous mode
Sat Jan  1 00:02:26 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1.1) entering learning state
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:ff:40:f0:e9 mcast address from master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1.1) entering disabled state
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap1.1
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] bdg10: port 1(vap1) entering learning state
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: add 33:33:ff:40:f0:e9 mcast address to master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1.1) entering learning state
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] device vap2 left promiscuous mode
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2) entering disabled state
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 33:33:ff:40:f0:ea mcast address to master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:ff:40:f0:ea mcast address from vlan interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:ff:40:f0:ea mcast address from master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap2.1
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] device vap2.1 entered promiscuous mode
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:27 2000(GMT) [rv220w][Kernel][KERNEL] device vap2 entered promiscuous mode
Sat Jan  1 00:02:28 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:28 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 33:33:ff:40:f0:ea mcast address to master interface
Sat Jan  1 00:02:28 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2.1) entering learning state
Sat Jan  1 00:02:28 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:ff:40:f0:ea mcast address from vlan interface
Sat Jan  1 00:02:28 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:ff:40:f0:ea mcast address from master interface
Sat Jan  1 00:02:28 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2.1) entering disabled state
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: vap2.1
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] bdg20: port 1(vap2) entering learning state
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: add 33:33:ff:40:f0:ea mcast address to master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2.1) entering learning state
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: add 33:33:ff:40:f0:e4 mcast address to master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: del 33:33:ff:40:f0:e4 mcast address from vlan interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: del 33:33:ff:40:f0:e4 mcast address from master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: eth0.10
Sat Jan  1 00:02:31 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: add 33:33:ff:40:f0:e4 mcast address to master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] bdg10: port 2(eth0.10) entering learning state
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: add 33:33:00:00:00:01 mcast address to master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: add 01:00:5e:00:00:01 mcast address to master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: add 33:33:ff:40:f0:e4 mcast address to master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: del 33:33:ff:40:f0:e4 mcast address from vlan interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: del 33:33:ff:40:f0:e4 mcast address from master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: del 01:00:5e:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: del 01:00:5e:00:00:01 mcast address from master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: del 33:33:00:00:00:01 mcast address from vlan interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: del 33:33:00:00:00:01 mcast address from master interface
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] IPsec: device down: eth0.20
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: dev_set_promiscuity(master, 1)
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] bdg20: port 2(eth0.20) entering learning state
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.1: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] vap0: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] vap1.1: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] vap1: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] vap2.1: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] vap2: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: topology change detected, propagating
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 1(eth0.1) entering forwarding state
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] eth0.10: no IPv6 routers present
Sat Jan  1 00:02:34 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 2(vap0) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg10: topology change detected, propagating
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg10: port 1(vap1) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: topology change detected, propagating
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 3(vap1.1) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg20: topology change detected, propagating
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg20: port 1(vap2) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg1: port 4(vap2.1) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] eth0.20: no IPv6 routers present
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg10: port 2(eth0.10) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] bdg20: port 2(eth0.20) entering forwarding state
Sat Jan  1 00:02:35 2000(GMT) [rv220w][Kernel][KERNEL] ERROR:endChantRecv: protocol PNAC returned !OK
Sat Jan  1 00:02:22 2000(GMT) [rv220w][Local0-wireless][PNAC_USR] pnacUmiIoctlHandler: cmd: PNAC_PHY_PORT_DECONFIG(33)
Sat Jan  1 00:02:22 2000(GMT) [rv220w][Local0-wireless][PNAC_USR] Error from pnacPhyPortDestroy: port not configured
Sat Jan  1 00:02:22 2000(GMT) [rv220w][Local0-wireless][PNAC_USR] pnacUmiPhyPortDestroy: Failed to destroy the port
Sat Jan  1 00:02:22 2000(GMT) [rv220w][Local0-wireless][UDOT11] DBUpdate event: Table: dot11Interface opCode:23 rowId:1
Sat Jan  1 00:02:22 2000(GMT) [rv220w][Local0-wireless][UDOT11] DBUpdate event: Table: dot11Interface opCode:23 rowId:2
Sat Jan  1 00:02:22 2000(GMT) [rv220w][Local0-wireless][UDOT11] DBUpdate event: Table: dot11Interface opCode:23 rowId:3
2000-01-01 00:00:36: [rv220w][IKE] INFO:  IKE started
Regards Simon
Simon,
We have several issues w/ the log in this fw. Too many to describe. Dev team are currently working on hot fix right now. I'll let you know once it's available.
Don
Simon, which browser type did you use? and its version too. Btw, would you also try to clear cache and display log again.
Hi Don sorry for Belated reply, am busy with other things at present.
I am using mainly Chrome 13.0.782.112 m or Firefox v5.0
I have no proxy assigned and had cleared caches.  I also reported this to Tekai, too who has my backup router cfg
Simon
Regards Simon
Simon,
- Dev team was able to reproduce same problem that you're seeing. They are working on the fix.
- The hair-pinning and access-rule problem reported from Joergen Thomsen is also been analyzed and under investigation.
Thanks for prompting us these issues where it need to be fixed.
Don
