03-28-2020 11:59 AM
I have connected a spa112 to my sip anveo service, the line shows connected, i get a dial tone. when i dial a outside number it rings once then immediately goes to busy signal.
Solved! Go to Solution.
03-30-2020 06:04 AM
03-29-2020 12:11 PM - edited 03-30-2020 05:27 AM
Read SPA112 Call waiting- Busy line? It is very similar issue. Your case require same approach from you to solve.
Just capture SIP packet related to the failing call. We will be able to advise something then.
03-30-2020 06:04 AM
