WRP400 WAN x LAN bridge
Tomas Chott
Hello everybody
i have question about WRP400 is there some chance how i can set up WRP400 to bridge mode, like SPA2102.
Thank you Tomas
5 Replies 5
Patrick Born
Hi Tomas,
Yes. To configure your WRP400 to function in bridging mode, use a browser to access the WRP400's web-UI > Setup > Advanced Settings > Advanced Routing > NAT > Disabled
Disabled mode==Bridging mode
NAT mode==Routing mode
Edit March 17, 2009: The WRP400 does not support bridging mode. The Admin Guide currently implies that it does, but is referring to SPA devices. I will have the document updated to reflect that WRP400 bridging is not a supported feature.
Patrick
Message was edited by: Patrick Born
I would also like to bridge the WAN port with the four LAN ports, an equivalent setup as the "Bridge" networking mode for the SPA2102 (DHCP for the SPA2102 internet access and both ethernet ports bridged together).
Disabling the NAT does not seem to do this. I tested with firmware version 1.01.00 and 2.00.05.
Is it supposed to do this ? Does another option is needed, like Static IP for WAN setup instead of DHCP or else ?
Best regards.
Hi Frédéric,
I'm researching your question and will get back to you shortly.
Patrick
Hi Frédéric,
Bridge mode is not supported on the WRP400.
Patrick
Found this quite old thread. Am also looking for a device that does support bridging with VoIP functionality.
Could you do some research again, as http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps10024/ps10028/data_sheet_c78-502141.html still says, that is DOES support bridge mode. People are buying devices because of these specs, so the information should be accurate. I don't wan't to check the usermanual wheather the device does support it or not, (btw. I didn't find anything in the usermanual about bridging) So either user manual or spec is wrong, could you please tell me which one ?
regards
Gerhard
