05-18-2017 02:32 AM
I've just deployed 1000+ 7821 and 7841 phones.
Now the users are complaining that the phones aren't returning to the phone home screen after you make a call via directory or anything else.
Is this a configuration thing I can change or is it a 'feature'?
we have a load FW of sip78xx.11-0-1-11
Any help appreciated
Ian
05-18-2017 02:57 AM
Hello Ian,
We have tried the same with 78XX and with 88XX devices and its not reproducible from our end.
Is the issue reproducible from your end ? If yes, can you please pass me the steps you have followed to reproduce this issue ?
GK
05-18-2017 03:30 AM
Hi Gokul
it's every phone. We are running sip87xx.11-0-1-11. I havent noticed it
on the 88xx, just the 7821 and 7841. My test phone now has been on the
phone information screen for over an hour....
Any ideas appreciated
Ian
Ian Lewis
Senior Voice Engineer/Architect
Phone: +44 (0) 7795 666745 | Mobile: +44 (0) 7500 108206
E-mail: LEWISIAN@uk.ibm.com
IBM United Kingdom Limited
Registered in England and Wales with number 741598
Registered office: PO Box 41, North Harbour, Portsmouth, Hants. PO6 3AU
05-18-2017 05:18 AM
Hello Ian,
Can you please share me the steps you have followed on 7821 and 7841 and please attach the screenshot of the issue from your phone.
GK
05-18-2017 05:45 AM
Hi Gokal
So I took the phone out of the box, configured the usual basic settings,
added a line/partition CSS. Nothing special, no fancy config.
The problem is difficult to screenshot, if I go to the directory or the
phone options or anything off the home screen it never goes back to the
homescreen.
If I use the directory to make a call, when I close the call, the screen
returns to the directory screen and not to the home screen. you then have
to exit back to the home screen...
I have a 79xx series next to my test phone, with the same CUCM settings
and that works as I would expect. If you go to the directory and then do
nothing, or make a call, it will return to the home screen
Ian
Ian Lewis
05-18-2017 06:14 AM
Hi Ian,
Before registering the device with CUCM can you please Reset it once (Which is zero config) and register it with CUCM (Just a try) ?
Please share me the result after you execute this.
Gokul
05-18-2017 06:33 AM
Hi Ian,
if issue persists after trying the above, Please pass me the device logs by using PRT (Problem Reporting Tool).
Gokul
