CAXL integration stopped working after upgrading CUCM/IMP to 12.5 SU1 to SU3
hhbalfour
We have a web integration with Jabber that stopped working when we upgraded to 12.5 SU3.
https://developer.cisco.com/docs/jabber-web/#!im-and-presence-overview/overview
#CODE#
require('dotenv').config({path: __dirname +"/.env"});
var xmpp = require('simple-xmpp');
/* Connect to Cisco / XMPP Service */
xmpp.connect({
    jid: process.env.JABBER_ID,
    password: process.env.JABBER_PASSWORD,
    host: process.env.JABBER_HOST
/* Watch for Status changes */
xmpp.on('buddy', function (jid, state, statusText, resource) {
    if (resource == "composed") {
        // let value = Object.keys(io.sockets.in(jid).connected).length
        // console.log(value);
        console.log('%s is in %s state - %s -%s', jid, state, statusText, resource);
        io.to(jid).emit('presenceChange', { email: jid, status: state, statusText: statusText });
/* Create server */
var app = require('express')();
var http = require('http').createServer(app);
var io = require('socket.io')(http);
io.setMaxListeners(0);
http.listen(process.env.PRESENCE_PORT);
/* Await connection */
io.on('connection', function (socket) {
    /* User joins room */
    socket.on('join', function (data) {
              var userId = data.jid.toLowerCase();
        console.log("user joined", userId);
        socket.join(userId );
        /* Get inital status */
        xmpp.probe(userId , function (state, statusText) {
                   xmpp.subscribe(userId);
        io.to(userId).emit('presenceChange', { email: userId , status: state, statusText: statusText });
    /* Should be used by editing to ensure user is 'friend' */
    socket.on('subscribe', function(data) {
                           console.log("newsubscription:",data.jid);
        xmpp.subscribe(data.jid);
#ERROR#
{ Error [ERR_UNHANDLED_ERROR]: Unhandled error. ('XMPP authentication failure')
    at EventEmitter.emit (events.js:187:17)
    at Client.<anonymous> (D:\Node-JS-Apps\Jabber\node_modules\simple-xmpp\lib\simple-xmpp.js:477:20)
    at Client.emit (events.js:198:13)
    at Client._handleAuthState (D:\Node-JS-Apps\Jabber\node_modules\node-xmpp-client\lib\Client.js:295:10)
    at Client._handleStanza (D:\Node-JS-Apps\Jabber\node_modules\node-xmpp-client\lib\Client.js:233:12)
    at Client.onStanza (D:\Node-JS-Apps\Jabber\node_modules\node-xmpp-client\lib\Client.js:221:8)
    at Connection.emit (events.js:198:13)
    at Connection.onStanza (D:\Node-JS-Apps\Jabber\node_modules\node-xmpp-core\lib\Connection.js:377:10)
    at StreamParser.<anonymous> (D:\Node-JS-Apps\Jabber\node_modules\node-xmpp-core\lib\Connection.js:231:10)
    at StreamParser.emit (events.js:198:13) context: 'XMPP authentication failure' }
npetrele
What version were you using before the upgrade?  If you were using 11.5, for example, you need to change your BOSH port from 7335 to 5280.
