07-26-2016 12:01 AM
We created a service on Cisco IP phone 7975 in order to send a request to a controller to control the lights and the shades in a room. We were able to create the service successfully and the buttons but the request is not being sent (via XML). Can you please tell us the syntax of the request that we should send?
We used the following but it did not work: Notify:http:10.100.100.10:3001::Blind 1606 close
08-02-2016 01:48 AM
I have moved your post under IP Phone Services Community. Came across a relative url - Re: Controll LED on 79xx Phones .
Thanks and Regards,
Geevarghese
08-02-2016 08:27 AM
Can you provide some more detail about how you think this should be working, what you have configured, and the interactions with the room control service..?
