CUPI - How to create a Routing Rule with "send call to Call Handler"
fabien.bonic
Level 5
Level 5
I want to create a Routing Rule with "Send Call to Call Handler" using CUPI.
The request I use is :
POST /vmrest/routingrules HTTP/1.1
Accept: application/json
Authorization: Basic Y2NtYWRtaW5pc3RyYXRvcjpjaXNjb3Jlbm5lcw==
User-Agent: Jakarta Commons-HttpClient/3.0
Host: 10.20.2.223:8443
Cookie: $Version=0; JSESSIONID=F511D502909770999BDF5FA3A37ACA9B; $Path=/vmrest/
Cookie: $Version=0; JSESSIONIDSSO=5873D22DCB59FC3E740C187043CB2EE2; $Path=/
Cookie: $Version=0; REQUEST_TOKEN_KEY=-2667875700315158213; $Path=/
Content-Length: 319
Content-Type: application/json; charset=UTF-8
{"DisplayName":"testbug20060ter","Type":"1","State":"0","UseDefaultLanguage":"false","UseCallLanguage":"false","LanguageCode":"1025","RouteAction":"0","RouteTargetConversation":"PHGreeting","RouteTargetHandlerObjectId":"894acf6e-d271-41cf-af48-65e01e89e22b","SearchSpaceObjectId":"9f847fa5-095f-4281-a8d7-73c9faa112b7"}"
HTTP/1.1 201 Created
Set-Cookie: REQUEST_TOKEN_KEY=-2667875700315158213; Path=/; Secure; HttpOnly
X-Frame-Options: SAMEORIGIN
Location: https://10.20.2.223:8443/vmrest/routingrules/vmrest/routingrules/d2664c39-03a1-45c9-a9b8-7d548fa4f94c
Transfer-Encoding: chunked
Date: Wed, 15 Feb 2017 16:26:52 GMT
Server:
But when I look to the created Routing Rule on Unity Connection Administration Interface, there is no radio button selected for "Send Call to":
What is wrong with my request ?
Thank you,
Fabien
fabien.bonic
Level 5
Level 5
When I set the value "2" to "RouteAction", it works.
fabien.bonic
Level 5
Level 5
