cut off column info in cudli :vw_subscriber.activesync
stephan.steiner
It seems something got cut off in the description and notes as it only states
Description: A flag indicating whether Cisco Unity Connection
Notes: A flag indicating whether Cisco Unity Connection
I think there's something that should come after
stephan.steiner
here's another one: pLdapType in csp_subscribercreate. Apparently it's not just an int, but it's a binary combination of the attributes as a user with ldap sync and authentication has the value set to 3 (so 1 (ldap sync) & 2 (ldap auth) = 3).
Hi Stephan,
Can you provide the URL of the page you are referring to?
Adrienne
jocreed
I am working with the Engineers on trying to figure out whether or not the LdapType can be updated.  Stephan has a case open that I am working on and has referred to editing this for provisonal purposes in other threads as well.
I am hoping to get an answer to you soon.
Thank You,
Jock
